Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CXA8042 on the Sony DVP-S9000ES
Old 27th March 2002, 03:49 PM   #11
audio_cf is offline audio_cf  Sweden
This is taken from LC Audios home page
The filter used is a second order Linkwitz-Reilly made with high grade (Unmagnetic) Poly Propylene capacitors from Vishay International. The cutoff frequency is set to 102 kHz for maximum overtone transparency and 100% compatibility with the host CD.
///CF
Old 27th March 2002, 06:40 PM   #12
fmak is offline fmak
Default Zapfilter on the 9000ES
It is not at all clear what is said. If the Zap lets through everthing to 100 kHz, then it may well fry tweeters on SACD which is very energetic above 22kHz, the CD cut off frequency.
On CD, a cut off well over 22kHz will allow refelctions back into the audible frequency range and cause intermodulation.
LC needs to explain what the text means, and where the filter starts to roll off.
For you information I have the ZAP but WILL not use it on SACD until I know its characteristics.
CXA8042 on the Sony DVP-S9000ESHide this!Advertise here!
sony dvp-s9000es mods jpvnnvpj Digital Source 0 14th July 2007 03:50 PM
superclock for Sony DVP-s9000es fernando Digital Source 1 5th March 2006 12:17 AM
Sony DVP-S9000ES Digital Signal Tap wdavis009 Digital Source 0 31st December 2005 03:54 PM
