Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
SD Card Memory FLAC/WAV 192/24 player - ESS crescendo II - AK4495 - DV20A
Old 25th April 2018, 02:56 PM   #21
acidbrain is offline acidbrain  Netherlands
acidbrain's Avatar
I leave the DAC board at peace for now I ordered a new TCXO oscillator after identifying the 27mHz oscillator on the I/O board. It's one i used before and it has it's own powersupply.
I used coax cable from a wireless antenna to connect it to the board. Removing the old one was easy, just heat up the the whole oscillator.
Almost always a nice upgrade ! Even the LCD creen looks sharper(?) and the ghosting in the TFT got less.
CD player high stability clock buffer module low noise power (no TCXO included) | eBay
Old 25th April 2018, 03:23 PM   #22
acidbrain's Avatar
Now i'm going to try to tune up the powersupply from the I/O board.
Too bad that there is no real information about the main chip, the ESS Crescendo 2.
The rectifier is made of Schottky SB850 diodes, The 3x1500uF elco's are Panasonic FL ?
I can only find them on ebay, old stock perhaps. Changed them for FM types.
First regulator is a heatsinked LM350 which provides the current of almost 1A.
After that the 5V output goes to 3 LM317's and to the front display.
At that junction is again one 1500uF FL cap, changed it for 2 1500uF FM types.
The only thing that i can do is change the LM350 for a TPS7A4701 reg, it should provide the needed current.
On of the 3 LM317's is heatsinked and get's an input of 3.5 V, the 5V main voltage is lowered using 2 diodes in serie. Is it helpful to use caps over the diodes to bring down the noise ?
Old 26th April 2018, 02:04 PM   #23
phase is online now phase  United States
The series diodes works well to keep the noise down, itís when you only have one that it could be an issue.
Project looks like a rewarding one!
I have a somewhat similar project that uses an ak4495 dac board, a ďlossless turntableĒ SD card player, and a headphone amp all in one case. Am going through making improvements where possible much as you are.
Old 26th April 2018, 06:14 PM   #24
acidbrain's Avatar
Yes, i like this tuning very much and nice that you're working on someting similair.
Hopefully your I/O chip is an AK brand one.
ESS is hushhush about chipinfo, so i have to guess which regulator to change. The 2 LM317's have a output of 3,3V, the sinked one 1,475V. I think about changing that one.
The stock I2S cable is 15cm long and i'm gonna use shorter coax instead.
Still waiting for amps from China, it's free shipping but 3 weeks is al long time !
HIFI Fever OP03 Full Discrete Component Field Effect Input Dual Op Amp Module | eBay
MUSES02 dual op amp JRC new Japanese flagship high fidelity HIFI | eBay
Old 26th April 2018, 09:39 PM   #25
I donít want to muddy up this thread with too many particular details regarding my Frankenstein apparatus, but will comment on common features or modifications that are shared.
As far as power supplies go, one that I wanted to use for the sd player portion was a lt3042 board from ebay that was pretty reasonable, mine never functioned and I havenít gotten another. Others have had them work successfully, thereís both single and dual versions.
Dual Way LT3042 Linear Regulator Power Supply Board DC Converter Pre-amplifier | eBay
I did have good luck with larger VREF caps on my ak4495,
(2PCS) 4700UF 16V PANASONIC X-PRO ELECTROLYTIC CAPACITORS 16V4700UF AUDIO | eBay
I am interested in that discrete op amp you have coming, I am using one like this, is also get input. I tried a bipolar input Burson IV, from another setup, and it didnít work well there.
OPM2401 MK2s DUAL Offset Adj AUDIOFEEL DISCRETE OP-AMP Some as a OPA2301 | eBay
I have had good results with using Nichicon LF, in a 47uf size around the various digital circuits, and clocks. Any larger size and the lower impedance will likely create a resonance.
Mounting them directly to the ends of the smd decoupling ceramic parts works to keep the inductance down in between the parts, lower the chance of a resonance.
Snubbers on the rectifier diodes helped too, was inexpensive, and there wasnít much in the way on that portion of the board(s).
Old 30th April 2018, 03:35 PM   #26
acidbrain's Avatar
Looks like the LT3042 is the new king in town
Last mods i did make was to change the I2S flatcable into 7cm long coax.
Isolated the chassis from the powersupply ground.
I got rid of the TP regulator and use only 2 TPS7A4701 for AVDD /DVDD.
Now i'm just waiting impatiently for those opamps from China.
Old 1st May 2018, 09:21 PM   #27
The op amp(s) should be a nice upgrade.
Are the yellows pots for adjusting the offset?
What are your impressions of the clock upgrade?
Old 2nd May 2018, 10:16 AM   #28
acidbrain's Avatar
I just received the Muses02, indeed a good sounding upgrade over the stock 8820 type.
Those are Hans his posts and yes they are for zeroing the offset, my DAc has only about 15mV output, so i'm not going to change that.
Funny that you asked about the clock upgrade, i've just finished a positive Ebay review to rate the product. It does what a good clock upgrade has to do : a more refined, stable sounding dac. Easy to implement.
Did it before with a cd chassis
p.s. i don't know if the seller likes my added pictures because i replaced almost all the stock caps.
Old 5th May 2018, 09:46 PM   #29
Glad the muse parts worked out, the auction sites can be a little hit and miss.
The reason I asked about the clock board was because I had a similar board that made no difference in the sound of a dac I was working on. The usb receiver that it was supplying, died just a few days afterwards, so I abandoned the clock board the next time around...
Funny about the cap replacements; what do they expect when thy make decent stuff and then put the rot-gut caps on there?
Old 7th May 2018, 09:01 AM   #30
acidbrain's Avatar
The Muses02 is better than the 8820, but the discrete opamp beats them both. I'm almost satisfied with the sound performance.
The music can still be a bit too bright, i've changed some of the filtercaps into polystyrene caps and replaced the neighbouring smd resistors to Dale-Vishay rn55d.
Those resistors are hard to find in Europe if you want hem for a fair price, here's one
40x Dale Resistor (RN60C/RN60D) 1% Customerized Values | eBay
Bought 2 Amtrans AMCH capacitors for the filter to see if that helps.
Amtrans AMCH | Hifi Collective
I use ETI rca connectors but these are very expensive, i found a "copycat"on Ebay that looks really well. Should have known that earlier.
Star Line Tellurium Copper RCA Plugs connectors 2 Pair 4pcs interconnect cable | eBay
Yes, fake IC's, resistors, caps, etc. Some oriental Manufacturers use everything from everywhere. But it's a sport to locate and replace those parts.
The clock board seller didn't place my pictures
SD Card Memory FLAC/WAV 192/24 player - ESS crescendo II - AK4495 - DV20AHide this!Advertise here!
Which software to convert FLAC 24/192kHz to WAV Eric Juaneda Software Tools 20 14th November 2015 10:04 PM
How can I use TMS320 with PCM4202 to record to SD memory card ? gaetan8888 Digital Source 0 24th September 2013 01:41 AM
How can we interface the PCM4202 with a SD card to record wav file on a SD card ? gaetan8888 Digital Line Level 3 11th June 2013 02:05 PM
QA660-SD Card WAV APE FLAC MP3 24/192 transport cowboyab Digital Source 7 14th April 2013 02:11 AM
Does anyone have experience with this Ultra Low Jitter SD Card WAV Player? ncc Digital Source 20 21st March 2012 01:44 PM
