How to install a cd phase switch How to install a cd phase switch - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th February 2004, 06:46 AM   #1
jimmyinhawaii is offline jimmyinhawaii  United States
Default How to install a cd phase switch
Hi
I read some old message that teach how to install a phase switch for cd player.
It talk about the INV pin on the dac,what is the inv pin stand for and how to find the 0v and 5v.
Jimmy
Old 17th February 2004, 01:50 PM   #2
Klaus is offline Klaus  Germany
Hi Jim,
INV pin means the switched pin to activate the inverted phase mode of the DAC. At some older DAC ICs this was realized to use this DACs in full symmetrical applications. Check the datasheet of your DAC if this pin is available and how to switch. 0V and 5V would be like ground and V_supply but check datasheet.
Most newer DACs have no more INV mode, therefore they frequently have symmetrical outputs. Here one Inv-relay can solve the issue. I realized one INV-relay at my Aleph P1.7 preamp, so each signal source can be inverted.
Klaus
Old 18th February 2004, 07:19 AM   #3
Default cd phase switch again
Hi Klaus,
Thanks for the reply,is it ok to draw out a full circuit how to use a relay to made a phase switch.
jimmy
Old 18th February 2004, 12:30 PM   #4
Default relay inverter
Hi Jim,
Use a relay with two times change-contact, if you know what I mean. Connect it like shown.
I placed my inv-relay right in front of the input coupling cap of my Aleph P1.7 preamp. It works perfect!
Klaus
How to install a cd phase switchHide this!Advertise here!
Fostex 127E phase plug install kazoo Full Range 42 11th December 2006 07:54 PM
360 degree phase switch Puffin Subwoofers 19 18th April 2006 10:50 PM
360 degree phase switch Puffin Everything Else 4 10th April 2006 06:50 PM
Phase switch on Alpine MRV-T303 V12 amp WordUpOnLCDs Chip Amps 3 9th January 2006 04:07 AM
replacing two position phase switch with pot? crippledchicken Solid State 3 15th June 2005 01:41 PM
Copyright ©1999-2017 diyAudio
