| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#61 | |
((Mine did not work on XP before I did this. Bear in mind that I am running a lot of experimental software so it might have worked on my computer even without this workaround)) Petter |
#62 |
Changing it to 98SE compatibility got it to work on my machine.
So, it's bascially a calculator and a display window? No other function? Sorry for accusing you there.. have run into a lot of programmers that forget that their enviroment isn't like most other computer's.. Don't know what could be missing here.. though it is a couple year old install of XP Pro. |
#63 |
IF I understand this circuit correctly, it is a serial shift register.
And if the oscillator is working at 66 Mhz instead of 100Mhz, it is because the inductor forms a LC oscillator. Why not use a 20Mhz crystal tuned to its 5th harmonic? Why use a crystal at all? Very easy to make it oscillator into VHF-UHF frequencies. Tom EE |
| Decoder output: how jittery, worth reclocking? And "double" reclocking | hollowman | Digital Source | 0 | 17th July 2009 02:39 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 10:22 AM |
| Asynchronous reclocking problem | Andypairo | Digital Source | 11 | 23rd December 2003 10:46 AM |
| Asynchronous Clocking | weinstro | Digital Source | 0 | 12th June 2003 06:31 PM |
| First attempt at asynchronous reclocking | Oli | Digital Source | 2 | 25th May 2003 01:38 AM |
| Page generated in 0.08005 seconds (74.85% PHP - 25.15% MySQL) with 11 queries |
