Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th April 2004, 09:06 PM   #41
Pedja is offline Pedja  Serbia
If Ulas is not against it and if you send me your email address, I can send you the file, no problem.
Old 10th April 2004, 09:44 PM   #42
Banned
I put jitterdither.zip back on my web site.
I took it down because the only feedback I received about the program was that it didn't work and couldn't be compiled.
Old 10th April 2004, 09:50 PM   #43
Default Well, then...
It is the excellent thing. Works, no problem.
Old 11th April 2004, 09:15 AM   #44
JonPike is offline JonPike  United States
Just dl'ed it and it dosen't run on my XP system.. very fast blink, and nothing.
Old 11th April 2004, 09:25 AM   #45
Doesn't run on my 98SE system either!. I tried .exe on DOS also and again nothing happens.
Ulas, can you pl help?
Old 11th April 2004, 09:46 AM   #46
Right click the .exe file, select compatibility for Windows95. Worked for me
Petter
Old 11th April 2004, 04:39 PM   #47
Banned
JonPike, fmak, et al,
JitterDither works perfectly for me, right out of the box with no special options or settings of any kind, on every system I have tried, including Windows 98SE, Windows 2000, and Windows XP. The program is utterly simple: it’s just a standard dialog box and nothing else. If it doesn’t work for you there is probably something wrong with your computer.
Old 12th April 2004, 08:50 AM   #48
Or, it needs some VB runtime code that we don't have.. not everyone has a compiler installed.. Is everything included that it needs, or is it assuming that there are the right libraries available on the computer?
Old 12th April 2004, 01:22 PM   #49
Banned
JonPike, What do you want me to do? The program works on every PC I’ve tried, including my wife’s PC, which has never had a compiler or other development tool installed on it. The only libraries it has are the ones that came with WinXP.
Old 12th April 2004, 03:43 PM   #50
It would be good to have an explanation of how this works and what peripherals go with the working ones. It dosen't work on any computer I have tried; Win 98SE or XP!!
Decoder output: how jittery, worth reclocking? And "double" reclocking hollowman Digital Source 0 17th July 2009 01:39 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Asynchronous reclocking problem Andypairo Digital Source 11 23rd December 2003 09:46 AM
Asynchronous Clocking weinstro Digital Source 0 12th June 2003 05:31 PM
First attempt at asynchronous reclocking Oli Digital Source 2 25th May 2003 12:38 AM
Page generated in 0.09798 seconds (74.96% PHP - 25.04% MySQL) with 11 queries
