Why the USB/I2S card died ? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th November 2015, 07:56 PM   #1
NVD33 is offline NVD33  France
Default Why the USB/I2S card died ?
I have a Revox B226 cdp that does not read CD. I tried to fix it but no luck and it was taking dust on a shelf.
Recently, I have ordered from Ebay a DAC with an USB/i2S interface card based on XMOS circuit. Having this card at hand, I wanted to know if it is possible to modify the Revox cdp into an USB NOS DAC. I tried the modification, it was quite easy (see picture).
I connected my laptop using Foobar and it worked fine, I got the music for a week. I thought that all was OK, then I closed the cdp chassis. I still got music for the two following days but suddenly the music stopped, the laptop did not find the USB card anymore. I tried everything but no luck. I contacted the seller, he said that the USB card is not compatible with the TDA1541 ! Why it worked then for more than a week?
Can somebody help me to understand what was the problem ? I suspected a component overheat on the USB card.
Thanks in advance,
Old 14th November 2015, 02:51 AM   #2
i will first check if any voltage across the capacitors
Old 15th November 2015, 09:32 PM   #3
I have made the same mod to another cdp using another type of usb card. I put this usb card in the Revox but I could not get any music because this card is not compatible with the TDA1541 in the Revox but it did not kill the second usb card.
I asked the seller to provide me the schematic of the usb card but no reply. I will measure voltage across caps as you suggested.
USB isolator for asyncron USB to I2S converters koldby Digital Line Level 12 22nd December 2013 06:59 PM
Raspberry Pi I2S output as Asynchronous USB-to-I2S Tinco Digital Line Level 26 27th September 2013 03:18 AM
Will wireless USB hub lower the quality of my USB sound card output? rg12 Digital Source 6 6th January 2011 09:47 PM
I2S from Juli@ PCI sound card wackyterbacky Digital Line Level 27 13th September 2010 06:28 PM
Direct Wiring a DDDAC USB-->I2S to a P3A DAC I2S DIN input dkj7a Digital Source 1 26th March 2006 06:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
