Which Philips is the best ? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th February 2004, 08:36 PM   #11
Bernhard's Avatar
and all sections are shielded from each other.
Old 15th February 2004, 08:51 PM   #12
I suppose Cd880 will be the best among the ones you mentioned,but I'm no expert at this.
Bartek
Old 15th February 2004, 09:20 PM   #13
Lourens is offline Lourens  Europe
Default CD880
Originally posted by Bernhard
In a week I will get the 880.
Congratulations, Berhard!
Are you going to tweak it?
regards
Lourens
Old 15th February 2004, 09:23 PM   #14
Bernhard's Avatar
Default Re: CD880
Not really, I built an external 4 x 1541 S1 DAC.
Maybe the PSU...
Bernhard
Old 15th February 2004, 09:29 PM   #15
If you are going to use it only as a transport Philips 304MKII might be the best of them.
CDM 1 is suppose to be better than CDM 1/MKII.
I only don't know which of them sits in CD 960.
Bartek
Old 15th February 2004, 09:50 PM   #16
diyAudio Moderator Emeritus
jean-paul's Avatar
Default Re: Re: CD880
Maybe the PSU...
Bernhard
Be sure to make the SPDIF output right, it is the weakest spot in most Philips cdplayers. A better transformer will do wonders.
Even better; make that DAC inside the cdplayer without using SPDIF and go with I2S. The very best approach if you ask me.
What's up with the 4 x TDA1541A S1 thingie ?
It's only audio. Member of the non modular PCB design committee
Old 15th February 2004, 10:07 PM   #17
Default CD880
Here you can see a lot of nice pictures of the CD880 interior.
One thing puzzles me: the Internal ROM-software link shows a picture of an IC I do not have in my CDD882.
Is it part of the DAC?
Old 15th February 2004, 10:13 PM   #18
Bernhard's Avatar
Default Re: Re: Re: CD880
No space inside.
The 4 x TDA1541A S1 thingie:
Slowly but surely...
The preregulator board is finished 100x160mm
TL431 board also finished. 100x160mm
DAC board in progress. 100x200mm
Tube output stage board comes next. 100x160mm
PSU for tube output stage. 100x160mm
reclock ?
Already too much to put in a cdp...
What about I2S via shielded cable & maybe driver op amp to external DAC ???
Bernhard
Old 15th February 2004, 10:16 PM   #19
Bernhard's Avatar
Default Re: CD880
Make a guess where I got my new machine
Old 15th February 2004, 10:46 PM   #20
Bernhard's Avatar
Just had a closer look @ the 830.
CDM4/19 transport.
Spindle powered by Mabuchi.
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips CD 960 @lf Digital Source 13 16th October 2006 06:08 PM
Philips cd 931/00 jimraft Parts 1 12th November 2005 05:19 PM
Copyright 1999-2017 diyAudio
