Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Which Philips is the best ?
Old 16th February 2004, 06:28 AM   #21
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
And ?
Jean-Paul/ has seen some "better" mechanics that break down more often...
It's only audio. Member of the non modular PCB design committee
Old 16th February 2004, 08:19 AM   #22
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
And ?
The 820 with Mabuchi sounds definitely worse than the 650 with brushless.
Motors with brushes make a lot of noise.
Acoustical and electrical (RF).
Radio controled cars ( toys ) have ceramic caps across the Mabuchi motor terminals and to ground from each terminal.
The transports do not.
Little history:
I went to Munich to buy my first cdp in 1986 or so.
No informations from www this time...
Was scanning the shops with no idea what to buy.
Close to the main train station, there was a small shop in a back yard, owned by an arabic salesman.
After having seen a lot of 400 buck technics and other japanese stuff, this guy convinced me to buy the 1000 buck cd304. Without mkII yet.
Already got my zero automatic Thorens turntable with moving coil pick up from him a few years earlier, when I had a fancy Dual with full automatic and digital rpm display in my mind.
This CD304 served me until 2002 and I never had the feeling to need anything better.
My next CDP was the mkII with digital out from a flea market for 25 bucks
Now I'm looking for something more comfortable, with a-->b repeat and direct title selection.
Hope the 880 will do well.
The Technics SL-P770, the DENON DCD 685 and the Philips CD830 did not.
Bernhard
Old 16th February 2004, 08:54 AM   #23
jean-paul's Avatar
Are the motors the only difference ?!?! In other words, is the mabuchi motor the cause of deterioration of the sound quality ?
Although I have a preference for brushless motors as well I think you slightly exxagerate the difference in quality because of the motor alone.
There is not much really wrong with CDM 4/XX. In fact they are better than a lot of sophisticated mechanics with linear motors, brushless spindle motors etc.
Old 16th February 2004, 09:03 AM   #24
Bernhard's Avatar
Maybe it is the 1541 that sounds better than the 1541A
Old 16th February 2004, 11:50 AM   #25
Angelm is offline Angelm  Bulgaria
"Be sure to make the SPDIF output right, it is the weakest spot in most Philips cdplayers. A better transformer will do wonders."
Hello jean-paul,
I have CD 471 without digital out, could you advice me for good SPDIF tranformer ?
Old 16th February 2004, 03:44 PM   #26
Lourens is offline Lourens  Europe
Default Re: Re: Re: CD880
Or just remove it. Did wonders in my 882. Look and listen
Old 16th February 2004, 05:02 PM   #27
jean-paul's Avatar
I would not want to give up on galvanic isolation. Just the fact that grounds are separated with a transformer is enough for me. The actual location of the transfomer ( cdplayer or DAC ) is less relevant IMO. It seems to be common practice to have it in the cdplayer but several brands think different about the subject.
You should have compared both situations in your CD882 with a third option: a good transformer. To compare a plain bad transformer with a direct connection will be in favor of the direct connection I guess.
You can't advice on removing the transformer if you haven't done the comparison with a proper one.
Old 16th February 2004, 08:07 PM   #28
Bernhard's Avatar
Jean-Paul, where to get the proper transformer ?
Old 16th February 2004, 09:03 PM   #29
jean-paul's Avatar
Bernhard, do us and yourself a favor and try the Search function. It really works, at least for me it does. These subjects have been chewed on, spit out and chewed on again in various threads.
No need for repeating the same thing over and over again. It is all here.
Click the link Bernhard, don't be afraid. Just do it
http://www.diyaudio.com/forums/search.php?s=
Or try the direct link on Lundahl LL1566 if you are not that brave
http://www.diyaudio.com/forums/showt...=&pagenumber=2
Just joking Bernhard but diyaudio.com would be better off without 10 threads about the same things. Maybe it is good advice to gather the wanted info and save it into one document. I sometimes do and I make a PDF of it for readability. Comes handy for future reference ...
Old 16th February 2004, 09:30 PM   #30
Bernhard's Avatar
Like most subjets in this forum
The search function is not very comfortable, often you get mismatching results and have to search the whole thread.
The best would be to make the 0/0,5V 0/5V.
Which Philips is the best ?Hide this!Advertise here!
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips CD 960 @lf Digital Source 13 16th October 2006 06:08 PM
Philips cd 931/00 jimraft Parts 1 12th November 2005 05:19 PM
Copyright ©1999-2017 diyAudio
