Which is more susceptible to jitter Multibit or DS dacs - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th October 2015, 01:49 AM   #1
georgehifi's Avatar
Send a message via MSN to georgehifi
Default Which is more susceptible to jitter Multibit or DS dacs
Please all digital gurus settle a disagreement.
Which is more susceptible to jitter Multibit or Delta Sigma converters
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 27th October 2015, 03:41 AM   #2
Multi bit was introduced to get round DS jitter sensitivity.
This paper explains the DS limitations:
http://www.ece.tamu.edu/~spalermo/do..._saad_2012.pdf
Old 27th October 2015, 04:22 AM   #3
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Jitter noise/errors being introduced depend on the frequency being output by the DAC for the simple reason that the faster the signal's moving (i.e. slewing) the bigger the amplitude error introduced by a timing error.
Since D-S by design outputs a lot of ultrasonic energy (DSD being king of the pile, being only 1bit) that energy has the capability to be 'down-shifted' in frequency by jitter.
As to particular implementations of D-S - the DACs using switched capacitors (has to be those with integrated opamps e.g. Wolfson/Cirrus) are the least jitter-sensitive.
The smart way to keep people passive and obedient is to strictly limit the spectrum of acceptable opinion, but allow very lively debate within that spectrum. Chomsky
Old 27th October 2015, 04:55 AM   #4
georgehifi's Avatar
Didn't Multibit come before DS???
And that paper from what I read and can understand, it seem that CT DS is very sensitive to jitter, is CT the type used in audio? If not and they're DT DS are they also sensitive to jitter? More so than ladder multibit dacs?
"However, CT ΔƩ modulators suffer from high sensitivity to clock-jitter"
Cheers George
Old 27th October 2015, 05:08 AM   #5
abraxalito's Avatar
George, David's talking about multibit D-S, not multibit (pure and simple). Multibit D-S uses many fewer bits (max 6, typically 5).
CT type is used wherever there aren't switched-capacitor (i.e. DT - discrete time) output stages. That means any DAC without on-chip opamps. For example ES9018, PCM1794.
Old 27th October 2015, 05:26 AM   #6
georgehifi's Avatar
OK my mistake, let me re-phase my question.
What is more susceptible to jitter, R2R Multibit or Delta Sigma?
Cheers George
Old 27th October 2015, 05:30 AM   #7
abraxalito's Avatar
That question has an easy answer if the D-S is CT (no on-chip opamps). D-S CT is much more susceptible to jitter than multibit (non-D-S).
Old 27th October 2015, 06:13 AM   #8
The original R2R DACs are the least sensitive to jitter. Their weaknesses are linearity and cost. None were >16 bit and often less much in practice, with the worst problems at mid scale. Modern multi bit is a compromise, that aims to get the best of DS and the R2Rs
Old 27th October 2015, 10:08 AM   #9
analog_sa's Avatar
None were >16 bit
And the PCM1704 is what? 14 bit?
Old 27th October 2015, 11:52 AM   #10
jcx is offline jcx  United States
Default still waiting for jitter listening tests showing <10 ns threshold
https://www.hydrogenaud.io/forums/in...pic=51322&st=0
a lot of the theory assumes white random jitter spectrum for calculations
but in the real world we have quartz oscillators with low passed jitter spectrum
H I F I D U I N O: Clock in Buffalo II DAC
that should mean the highest amplitude jitter products are at small offsets from DAC output spectral components
by the 100kHz + frequencies that would give audible jitter product frequencies with Delta-Sigma shaped noise rising noise components typical quartz based clocks have <-120 dBc phase noise components
RD30 Quad multibit d/a converter Lupulroz Musicaltech 38 1st January 2016 10:10 PM
Multibit dac chips - R2R resistors. C6H5COONa Parts 2 12th February 2015 02:22 PM
a new multibit DAC chip Arda technologies AT1401 Shinja Digital Line Level 77 20th January 2014 02:22 PM
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 02:07 PM
Data Jitter Versus Electrical Jitter? 300_baud Digital Source 8 16th July 2004 07:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
