Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th February 2004, 10:52 PM   #1
Default EIJ on CDPRO2
hi
i built the cdpro2 and also the tda1545 dac.
but can't use them as the cdpro2 outputs i2s and not eiaj. any idea how to make the cdpro2 output eiaj?
it seems i need to do something to the dsa software. but i have no idea how. can i do it hardware wise?
please advise.
thanks.
donjuan
Old 13th February 2004, 11:35 AM   #2
I've done this with vae1250 mechanism, i guess the command set is the same. I should search for the modified eprom, but as VAE1250 is discontinued I don't have them anymore to test.
Anyway you need an eprom programmer to burn the soft...
Old 13th February 2004, 12:23 PM   #3
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
The cdpro2 unit does support EIAJ, and a simple command needs to be issued over the DSA interface. I don't know you have your control board setup, but here is the command that needs to be issued.
Brian
Old 13th February 2004, 01:39 PM   #4
Bricolo is offline Bricolo  France
Bricolo's Avatar
Brian, when you use the 2FS or 4FS mode, is it oversampled or upsampled?
Old 15th February 2004, 01:13 PM   #5
hi guys
thanks for all the reply.
any other way other than dsa communication using a pc? i was hoping for hardware changes but looks like fat chance...
donjuan
Old 15th February 2004, 02:12 PM   #6
Why hardware not software?
Old 15th February 2004, 04:11 PM   #7
BrianGT's Avatar
I am pretty sure that it is just oversampled for the CDPRO2, from looking over other information regarding the dac. The new CDPRO2M might be different.
Originally posted by DonJuan
hi guys
donjuan
In terms of the control board, if you were using my control board, I would just need to make a small modification to the firmware. I might eventually add the selection to a menu-driven interface.
I will organize a group order sometime in the future for the controller that I designed.
Gallery from my project at:
http://brian.darg.net/cdpro2
Brian
Old 16th February 2004, 01:22 PM   #8
why hardware but not software?
well, if it's hardware, it's easier for me to incorporate. i can't access the firmware inside.
hi brian
interested in your controller!
donjuan
Old 17th February 2004, 04:09 AM   #9
cm is offline cm  Singapore
I have done a EIAJ to I2S converter by delaying the LRCLK EIAJ signal by 7 BCK clock cycles by means of a shift register. You can see the schematic and PCB in my post on sharing my digital work.
I have not tried it but I see no reason why the scheme cannot work by delaying data by 7 clock cycles instead of delaying LRCLK as a means of converting from I2S to EIAJ.
How to reclock CDPro2? cartman Digital Line Level 1 5th May 2009 07:52 PM
DSA protocol for CDPRO2 billr Digital Source 3 4th April 2005 09:17 AM
philips CDPRO2 Joules Digital Source 4 12th January 2005 08:06 PM
CDPRO2- do you just add PS? lgreen Digital Source 7 24th February 2004 09:48 AM
Page generated in 0.10387 seconds (82.37% PHP - 17.63% MySQL) with 11 queries
