New DAC with measurements! - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th February 2004, 12:57 AM   #21
ojg is offline ojg
Schematic is now up on the website as a pdf file.
Some of the component values may be slightly different from what I ended up using, but it should be mostly accurate.
Happy reading!
Old 29th February 2004, 03:40 AM   #22
Hello Olj,
Thanks a bunch and much appreciated!
Old 7th March 2004, 08:28 PM   #23
ojg is offline ojg
I have now replaced the OPA627 with AD825 as I/V converter. In my latest tests AD's $2 op-amp beats BB's $12 op-amp on every account! (And yes that includes the subjective listening tests!)
Have a look for yourself at the project website.
I recommend everyone on this forum to throw out their OPA627's!
(/me ducks and puts on flameproof suit....)
As a sidenote, I listened again to the DSotM track I mentioned before, and could not find the section with the annoying sound. In fact the old cliche is true, I forgot to listen to the 'sound' and started enjoying the music instead. Proof enough for me.
Old 7th March 2004, 08:45 PM   #24
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default just a little error
the 3rd IMD graph is called opa627, or it's with the ad825
Old 7th March 2004, 09:28 PM   #25
ojg is offline ojg
D'oh! Should be fixed now...
Old 7th March 2004, 10:08 PM   #26
diyAudio Moderator Emeritus
jean-paul's Avatar
Maybe they behave bad just in your DAC ....
It's only audio. Member of the non modular PCB design committee
Old 8th March 2004, 08:44 AM   #27
JonPike is offline JonPike  United States
Interesting results.. You should try the AD825's with the TDA1541 to see what difference there might be from the 5532's.
Another thing, though possibly harder, would be to try interfacing the 1541 to the DF1704 filter.
I've seen an article (Analog Devices app note AN-207, sorry I don't have a link) on changing the data stream such that a AD DAC could use the SAA7220 filter, it just took a few logic gates.. probably the same could be done to patch the other two together. Too late for me to look into it tonight..
Great to have measured results on a project like this.. I think you've just about inspired me to build something myself.. got a 1541 just sitting around gathering dust.
Old 9th March 2004, 02:19 AM   #28
ojg is offline ojg
Thanks, but I probably will not experiment more with the TDA1541, I used its measurements as a comparison base for my own DAC.
Good luck with your own project, may I recommend AD1896@192kHz - TDA1541 - AD825, should perform great and requires no glue logic.
I hope you will post your results here when you get it done. I will measure it for free if you send one my way
Old 9th March 2004, 04:32 AM   #29
Terry Demol's Avatar
Hi Ojg,
Why 192k? Can you hear any difference with 1896 at different
SR's?
Terry
Old 9th March 2004, 03:47 PM   #30
ojg is offline ojg
No I have only tested the AD1896 at 97.6kHz, but the TDA1541 max out at 192kHz (or 176.4kHz?).
You want to use the maximum frequency the DAC can handle to make the analog filter as simple (low-order) as possible. This I believe does make a difference on sound quality.
Cheers!
XAB Measurements DarkOne Pass Labs 12 16th April 2006 10:59 PM
New T-Amp measurements Pano Class D 12 14th March 2006 11:32 AM
SW measurements Grandma´s_SUB Everything Else 9 10th January 2005 01:34 PM
anyone have measurements of TB 871? morbo Multi-Way 5 27th November 2004 03:10 AM
Some CCS measurements Jocko Homo Solid State 10 29th May 2002 12:54 PM
Copyright ©1999-2017 diyAudio
