Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th February 2004, 12:40 PM   #1
Default Modding a XR45: adding USB port.
I plan to mod my panasonic XR45 digital receiver. My main goal is to get rid of jitter.
I want to add a USB port to the panasonic by just putting a M-Audio Sonica USB (http://www.short-media.com/article.php?115) inside and wiring the SPDIF line out of the Sonica to the AKM 4114 spdif receiver in the panny. I would bypass optical/coax.
Do you believe this would reduce jitter? (as there would be no optical/coax cables involved)
Andres
Old 18th October 2004, 03:20 PM   #2
bump
Any success witht this project yet? I've got a couple of XR10s, and I'm really intrigued by all of the PC-audio activity lately. TIA - Pat
Old 18th October 2004, 03:25 PM   #3
At the end the Sonica is not very reliable under heavy CPU load. The USB interface in the PC gets hit and the audio gets choppy, so I left with the impression that USB 1.1 is not enough for sound.
I have one space SA-XR25 (in addition to the XR45) and I already got all the parts to make: High Resolution Multi-Channel Digital Interface
Now I just need time!
-Andres
Old 30th October 2004, 12:36 PM   #4
raxy is offline raxy  France
jitter takes places on the spdif portion of the path,
you'd better try to output the classical LRCK,SDATA,CLOCK signals before the spdif line driver of the sonica.
Connecting the out clock of the sonica to the pany's will eliminate jitter by construction.
Old 1st February 2006, 04:21 PM   #5
I'm still thinking about this. I'm using a Squeezebox via coax to the XR10 now, but I'd like to add a USB-in to the receiver and go directly from the computer to the receiver.
So, is it as simple as just adding a USB-I2S board, such as the dddac, and wiring the I2S outputs to the Equibit board, as outlined in this post:
http://www.diyaudio.com/forums/showt...ht=#post241476
or is more required, such as additional logic or other conversion steps?
I'm a newbie with regard to this stuff, but I'd appreciate any advice that anyone could offer.
Thanks - Pat
Help with Pan XR45 / DCX2496 configuration ultrachrome Class D 3 26th November 2005 08:52 AM
Adding Vol Port to this LM3886 Circuit! FREQUENCY Chip Amps 12 12th March 2005 09:08 AM
Panasonic SA-XR10 vs SA-XR45/70 Snoodge Class D 1 16th December 2004 07:17 AM
Adding a Port to my enclosure Maples Multi-Way 6 26th July 2004 06:29 AM
Adding a port Howard Multi-Way 35 15th August 2003 09:06 PM
Page generated in 0.07276 seconds (76.97% PHP - 23.03% MySQL) with 10 queries
