Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
TDA1543 X 4 NOS passive low pass filter I/V. Wow!!!
Old 8th August 2015, 03:54 AM   #1
ridikas is offline ridikas  United States
Default TDA1543 X 4 NOS passive low pass filter I/V. Wow!!!
This DAC looks insane! I'm curious to hear feedback if anyone has built anything similar.
Old 8th August 2015, 05:19 AM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I'm not seeing much passive filtering there - just several caps to GND on the DAC outputs.
Can't quite understand why so many CM chokes on the secondary side - better economy of copper and core would be achieved by putting those on the primary side. Single inductors would replace CM chokes on the secondaries.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 10th August 2015, 05:16 PM   #3
DF96 is offline DF96  England
The Rref and I/V resistor values look wrong; that circuit has 390 and 680 respectively. For four TDA1543 in parallel from an 8V supply rail you need Rref between about 250 and 300R and I/V about 250 to 400R. See TDA1543 passive I/V resistors for my understanding of this. Use the wrong values and you get asymmetric peak clipping. The extra 'filter' resistors and caps may be a weak attempt to smooth away the resultant distortion.
TDA1543 X 4 NOS passive low pass filter I/V. Wow!!!Hide this!Advertise here!
Passive line level low and high pass filter help Matttcattt Multi-Way 54 28th July 2015 08:46 PM
RLC Filter for low pass filtering of the TDA1543? freax Digital Line Level 4 21st August 2014 01:22 AM
Passive, low pass filter issue. JSmith1980 Power Supplies 12 13th July 2014 05:31 PM
Passive low pass filter for subwoofer sybeandringa Analog Line Level 2 8th July 2014 12:59 AM
passive i/v stage - low pass filter lordearl Digital Source 9 6th November 2012 12:34 PM
