diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   SM5840....DF1704..changing digital filter ? (http://www.diyaudio.com/forums/digital-source/27776-sm5840-df1704-changing-digital-filter.html)
Lyra 8th February 2004 02:22 AM
How good is the old SM5840 ?
Would it be an idea to change it for a DF1704 ?
The SM5842 should be an outstanding performer (I read...) but I can't find anything about the "quality" of SM5840.
The data sheet indicate that the "numbers" of the DF1704 is better versus SM5840....but that doesn't mean better sound ?
According to the schematics the signalflow now is: EIAJ -> SM5840 -> CF37606 -> SM5828 -> AD1862
According to the frase "simpler is better" my choice would be: EIAJ -> DF1704 -> AD1862
This would be more understandable too, as I dont have a clue what the CF37606 is.....can't find anything regarding this chip....:rolleyes:
Lyra
rfbrw 10th February 2004 02:57 AM
I would have thought it was irrelevant what anyone else thought of the SM5840. You either like it or you don't.
As for the CF37606, you could see if your national library holds a series of databooks in its reference section by a company called
Derivation and Tabulation Associates Inc. (D.A.T.A) They compile huge databooks on nearly every IC on the planet, broken down into classes, and the discontinued devices book may have the information you seek.
Lyra 10th February 2004 03:34 AM
Yes...it is....but I have not heard the other one yet, and I don't know if I am missing something.....:xeye:
The function of the CFxxx chips are as far I can see not neccesary anylonger, but I dont know If it oversample the signal or not.
The SM5840 can oversample 4, or 8 times, but this is controlled by the controller.
My thought was that the DF1704 could be hardwired to the correct function, no matter wat the controller try to set.... + the DF1704 is a decade newer chip.....that shouldn't be so bad....I think.
Much!!! have happened in the digital prosessing front since this SM5840 left the plant.
The player plays nize !, but if there are more to get.....I want it !:smash:
.....and, simple is often better...I like to believe that anyway :hot:
Lyra
rfbrw 11th February 2004 04:15 PM
You could use the SM5847 or the DF1704 as both will probably be an improvement on the SM5840.
kimschips 26th September 2005 08:12 PM
Hello Lyra.
Great thread.
I have an Onkyo cd-player with CXD2500->SM5843->SM5861
I have also thought about replacing SM5843 with DF1704 and SM5861 with PCM1798.
Have you tried your ideas from post one?
Is EIAJ format the same as Right justified format with 64FS?
(Would like how to set DF1704 to accept EIAJ from CXD2500)
All the best
Kim
Jocko Homo 26th September 2005 09:18 PM
Where are you going to find the AD1862s? Just curious.........
Jocko
Fin 27th September 2005 02:51 AM
Did someone mention SM5842??
If you need SM5842APT or SM5843AP1 - I can help. :D
Cobra2 27th September 2005 07:22 AM
To make it easy....
http://www.audiotuning.de/index.html?1-51-digital.html
Arne K
rfbrw 30th September 2005 11:29 PM
Re: Did someone mention SM5842??
How much do you want for the '5842?
Fin 1st October 2005 09:25 AM
Re: Re: Did someone mention SM5842??
Send me a private mail and we can discuss it.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
