| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 |
I believe it's for the common-mode rejection:
"The following pairs of resistors must be matched to a tolerance of ~0.1%: RD22-RD24 RD26-RD28 R604-R602 RD21-RD23 RD25-RD27 R603-R601 R602 and R601 can be replaced with trim pots to fine-tune the CMR but this is probably not necessary. In order to adjust, disconnect RD22 RD24 from the DA converter. Apply a sine wave to both resistors and adjust R602 for lowest output (pin 1). Then do the same for RD21 and RD23 adjusting R601." It made a big difference in sound and especially depth... |
#42 |
Does the CD48 is equal or not to these units in the service manual? Miguel |
#43 |
The common-mode signal being digital switching noise etc. I think I'll probably go with matched 0.1%. Adding a trimpot is fiddly, and I'm not sure how much room there is. We shall see.
Next step is to look up the AD825 and LM6172 data sheets. I'm surprised nobody suggested OPA2134.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#44 |
I use the 2134 and 2604 and can't make my mind up. Seems to me that the 134 sounds softer and more detailed (contradiction?)
When I get around to it I'll throw in a 627 (I only use the first opamp) on a veroboard and see what happens, but I guess the 12V supply needs to be a cleaner first... |
#45 | |
#46 |
Thanks EC8010, IŽll try that.
Miguel |
#47 |
Ergo suggested above to use the alst two FET of the HDAM to improve the output capabilities:
Is there any reason for not cutting the trace AFTER RH17/18? What about the "feedback" to QH01/02 from before RH23/24? While I am at it: I have read about the 5V noise in the CD63 and now I wonder if anyone out there has any concrete ideas for a post-regulator (or alternative supply) for the 5 and 12V rails? Veroboard would be convinient as I don't have any good lab facilities. I have been thinking about using the holes for the remote control rca contact on the back as an input for separate supplies. I believe there are voltage input contacts that have a built-in switch that breaks a circuit when a plug is inserted. In this way the on-board rails are used when no plug is inserted and switched off when an out-board supply is connected. What do you think about that arrangement? Cheers, Tom |
#48 |
LM317 (+ve) and LM337 (-ve) are adjustable regulators that produce less noise than most of the fixed regulators. Do a search, and you will find from the manufacturer's data sheets that they are very easy to use, and Veroboard is fine. You can't regulate a 5V rail from another 5V rail, so what you do is to find the existing regulator, and pick up the voltage going into it, and regulate that for your quiet requirement.
#49 |
#50 |
Well, blow me down with a feather! It's an LM317. It's a minor point, but when tantalum bead capacitors fail, they fail short-circuit. This can often be a cause of smoke. Modern electrolytics are easily as good as tantalums, and they're cheaper and less risky.
| Marantz CD-84/CD-74 service manual? | bleachershane | Digital Source | 5 | 4th March 2012 11:00 AM |
| Marantz St-83 service manual | chicco_36 | Digital Source | 1 | 19th December 2010 08:24 PM |
| Marantz PM-50 Service Manual | senee | Solid State | 0 | 6th September 2008 03:23 PM |
| service manual marantz sa-11 s1 | ABO | Digital Source | 3 | 28th February 2008 12:34 PM |
| Marantz CD43/53/63/67 questions | monguz | Digital Source | 10 | 11th July 2003 10:29 PM |
| Page generated in 0.11159 seconds (76.71% PHP - 23.29% MySQL) with 11 queries |
