You measure it here (1st diagram) where it should be zero volts. You can also pick the direct mute feed from the system control here (2nd diagram) which might be easier to find. Again it should be zero when playing a disc.
Next steps would be to use an oscilloscope and check for audio at the output of the D/A convertors.
This sounds a strange problem... the fact it 'plays' and is fully functional apart from actually having audio present suggests it could be a fairly deep seated fault.
We always check the basics first which means checking all the appropriate power rails are present. At this stage that means confirming +12 and -12 volts is on pins 8 and 4 respectively of the upc4570 opamps. There should also be +5 and -5 on pins 16 and 8 of the AD1861 D/A convertors. Hard to see there could be a problem there as they are duplicated but check anyway. Any problem there could conceivably reflect back and corrupt the data applied to both convertors.
Beyond that and a scope is probably required to dig deeper into what is going on.
- Digital Source
- Denon DCD-1290 no sound
