| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Electrons are yellow and more is better!
http://www.kedab.se/Intro%20Index_fi...onProjects.htm
I stumbled across this by misstake. Magnetic suspension for a CD player.
/Per-Anders (my first name) or P-A as my friends call me |
#2 |
#3 |
If my eyes are not mistaken, I think it´s only using magnetics as vertical suspension. Looks like it uses some kind of guidelines so it won´t "fall" of.
I think there are better ways than magnetics anyway |
#4 |
Account Disabled
This tends to come up again and again.
Of course it has guidelines. Earnshaw's theorem: it is not possible to achieve static levitation using any combination of fixed magnets and electric charges. So, you either need an active system (i.e. the levitating spinning top or electromagnet with feedback system), quantum effects (i.e. an object put on a table levitates a tiny amount over it instead of passing through the table), or diamagnetic levitation (the only practical way to get sufficient effect is to use a superconductor as the diamagnetic material). Finally, magnetic levitation won't prevent, and worse, won't damp any vibrations from the air (sound). Do vibration isolation the way it's done in labs -- I've seen a confocal (laser scanning) microscope setup using a heavy marble base, lots of sand, and pneumatic dampers. |
#5 |
something similar it the Relaxa-1 table. You can find some review http://www.tnt-audio.com/accessories/relaxa1_e.html
Fabrizio |
#6 |
What strikes me about this design is that black plastic cover is flush with aluminum block. If this is the case, handling CD is very difficult as there is not enough clearance for the fingers to get hold of the edge of the disk.
Otherwise seems like an interesting approach. |
#7 |
yes it would be but it looks nice
#8 |
what about the cd's being a little of centered and wobbleing and or the bottem getting scratched..
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#9 |
If the CD is wobbling that much you'll have big problems regardless.
#10 |
As long as aluminum part is not higher than the plastic lens protecting cover, the CD has no way to touch anything, unless of course you were using it for other purposes previously
| fs3 suspension | phildcamp | Subwoofers | 4 | 29th October 2008 12:29 PM |
| Self-centering Magnetic Suspension? | Stocker | Everything Else | 5 | 8th February 2006 01:56 PM |
| Suspension collapsed | davidsrsb | Analogue Source | 4 | 26th January 2006 08:06 PM |
| Suspension Grommets | JonesS | Analogue Source | 2 | 17th November 2005 02:20 AM |
| Magnetic suspension linear-tracking tonearm? | Shaun | Analogue Source | 5 | 4th June 2003 11:21 PM |
| Page generated in 0.10404 seconds (76.76% PHP - 23.24% MySQL) with 11 queries |
