Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Stuck on reclocking part of Doede's 1543 DAC
Old 5th February 2004, 11:38 AM   #11
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Peter,
I have a 5*1543 tower
I first added 3m copper tap on top of each TDA1543 with a little sticking out the side..
THEN
I added heat conducting plastic (cutout from TO220 plastic..don't know what to call it) Then soldered on the next TDA143 and so on....so I have a sandwich of tda..copper tape..heat conducting plastic...tda etc, etc.
And then folded the 3m copper so it would touch the next little foldout of copper...and soldered that all together.
Unfortunately only on one side...
Then on that one side I added a 2,5mm copper from installatiedraad...made a little shape S..as soon as it protruded from the tower
BUT as you see that little copper thing broke of in the subsequent mods.(3m copper tape tore off). so on the photo the little antenna heatsink is off.. but before it broke off it worked quite well.
Now...without the little "antenna" it gets so hot it that putting on your finger is uncomfortable (8vdc supplied to the TDA1543)
But in the future I might try the tower with 8 and the heatsink with the Frontpage designer stuff...that is mentioned on doede's site.
I suggest you add the Wildmonkeysects mod right from the begining...Doede says it make very little difference with the reclocking on but Elso Kwak says it makes a big diffrence on a non reclocking dac.
Bas
Old 5th February 2004, 01:44 PM   #12
Guido Tent is offline Guido Tent  Netherlands
Originally posted by Bas Horneman
[B]
Is either the tent clock or that other thing very sensitive to soldering or electrostatic charges?..
/B]
never had one down due to ESD, some died after 15s soldering, but you all use a socket, nah ?
Take care to use clean power supply to make optimum bennefit from the XO, and makes sure all the wiring from and to the switch is twisted with a ground wire in company
regards
Guido Tent
www.Tentlabs.com
Old 5th February 2004, 01:52 PM   #13
Thanks for chipping in Guido.
Never occured to me to use a socket :-(
So soldered in straight..I also soldered a 47r resistor straight to the 4040 thingy...
Measured voltage on the signal going to the 4040 jobby and measerued 2,68vdc before going to 4040 after 47R resistor 3,6vdc???
Mean anything to anyone?
Bas
Stuck on reclocking part of Doede's 1543 DACHide this!Advertise here!
Decoder output: how jittery, worth reclocking? And "double" reclocking hollowman Digital Source 0 17th July 2009 02:39 PM
Jung Super Regulator in Doede's 1543 DAC audionut Digital Source 0 26th February 2008 05:43 PM
Stuck in reclocking rotel cdp sguazz Digital Source 1 18th February 2005 05:07 PM
Complete built DDDAC (8×TDA 1543 Doede Douma DAC) for sale krishu Swap Meet 6 19th March 2004 03:25 PM
Stuck as a Duck on the Doede Dac! Lucas_G Digital Source 57 3rd February 2004 10:49 AM
Copyright ©1999-2017 diyAudio
