After read the thread about
http://www.diyaudio.com/forums/digital-source/140538-lossless-sd-card-player.html
I want to have an overview of such devices. Until now I have found this brands only in portable versions:
1) Calyx M
Calyx M for the U.S.A. & Canada
Calyx Audio: The Calyx M | Headphone.Guru
DAP-off: Astell&Kern AK240, HiFiMAN HM-901, Sony ZX-1, FiiO X5, Chord Hugo, Calyx M, Aurender Flow, Lotoo Paw Gold
Produktvorstellung: Calyx M - digitaler Audioplayer der Referenzklasse, Mobiles Hifi / iPod / MP3 Player - HIFI-FORUM
2) Astell & Kern
Astell & Kern AK120 Portable Music Player Reviewed
Astell&Kern
Astell&Kern
Astell&Kern AK 100 im Test - AUDIO
Astell&Kern AK100 portable media player | Stereophile.com
3) FiiO
FiiO-Love music,love life,love FiiO!
Fiio X3 im Test - AUDIO
Unfortunately a lot of money is to pay for the integrated top class D/A converter, the accu/battery and the charger stuff so as the top-class enclosure for portable application. For this reason I am looking for devices in versions only for use as home-audio application with S/P-DIF output and without integrated DAC.
Which lossless player for SD card in this kind are on the marked?
Thank you very much for advices.
1) Calyx M
2) Astell & Kern
Astell&Kern
Astell&Kern
3) FiiO
Here a home audio version from a digital audio player resp. digital music player for SD cards, but still with integrated D/A converter
QA660--SD Card WAV Hi-Fi Digital Audio Player
http://www.diyaudio.com/forums/digital-source/225700-qa660-vs-qa550.html
http://www.whatsbestforum.com/showthread.php?9427-SD-Card-digital-music-player
http://www.box-designs.com/main.php?prod=mediaboxs&cat=source&lang=en
http://www.olive.us/
thank youCheck out the SMSL X3.
http://i00.i.aliimg.com/wsphoto/v0/...WIFI-lossless-SD-card-media-player-silver.jpg
Smsl x3 wi-fi lossless streaming media player - AudioKarma.org Home Audio Stereo Discussion Forums
also the M6 seems to be of interest - unfortunately the homepage isn't in English
http://smsl-audio.com/index.php?c=msg&id=1272&
check out also this thread
http://www.diyaudio.com/forums/digital-source/252985-sony-hap-z1es-hi-res-source-new-2014-a.html
thank you.aune m1
you can modify the dac and amp section, or by pass it.
http://forum.doctorhead.ru/index.php?showtopic=27350
http://www.soomal.com/images/doc/20140716/00044213.jpg
Aune M1 Hi-Fi Wav Player
Aune M1 Portable Hi-Fi WAV Player - Noisy Motel
If you are considering a pre built boards, why not think of Beagle Bone Black with Volumio installed on the internal MMC and it has the Built in SD card reader.
You can use USB out to feed your DAC
This Taobao seller in Chengdu has numerous options of player, the cheapest one excludes an internal DAC - https://item.taobao.com/item.htm?spm=a230r.1.14.64.39ffpk&id=36217520144&ns=1&abbucket=13#detail
- Digital Source
- Commercial available Lossless SD Card Player without integrated DAC
