Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD84 grease lube
Old 19th March 2015, 11:04 PM   #1
MaccAu is offline MaccAu  Australia
MaccAu's Avatar
Send a message via AIM to MaccAu Send a message via MSN to MaccAu Send a message via Yahoo to MaccAu Marantz CD84 grease lube
Default Marantz CD84 grease lube
Ive tried to searching but I cant find what greae/lube is suitable for the tray. The old grease was a thick grey looking grease. the CDM-1 mech is japanese version of the CDM-1.
Sam
1980s are rad
Old 20th March 2015, 12:35 PM   #2
Mooly's Avatar
I've always used Electrolube SPG (Special Plastics Grease) for most CD repairs. I see its available from Amazon,
http://www.amazon.co.uk/Electrolube-.../dp/B008RKXPCU
http://www.electrolube.com/products/...ricants_other/
Old 20th March 2015, 02:43 PM   #3
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
For the tray, I use dry silicon spray as it doesn't attract the dust and dry up.
Silicon based furniture polish was recommended by Grundig UK.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 20th March 2015, 10:10 PM   #4
MaccAu's Avatar
Thanks Mooly. That looks a great product. I'll see if i can find it around on ebay.
Thanks Jon,I use a Silicon based oil on the CD rails which seems to really help the disc track. Maybe a grease based form might suit
The tray appears to be metal or plastic the rollers not sure. I cant get rid of all the old grey grease? would that matter
1980s are rad
Old 21st March 2015, 01:31 AM   #5
MaccAu's Avatar
Hi Mooly,
You can merge the post if you like. I found the SPG35L at ELement14.
This is the current spray i use on the CD rails - Silicone Spray Lubricant.
WD-40 | PRODUCTS
1980s are rad
Old 24th March 2015, 11:26 PM   #6
Willi Studer is offline Willi Studer  Serbia
Any spray, whether teflon or silicon based, contains more or less oil which might destroy MBR rubber belts and O rings, so any surface in contact with rubber should be cleaned, degreased and left dry. Dry silicone spray is good on plastic cogs, although grease lubricant for printers is better because it reduces wear. For sliding surfaces in metal, silicone spray does not work well because the thin layer wears off quickly. Grease is much better there.
Marantz CD84 grease lubeHide this!Advertise here!
Marantz cd84 repair wheijke Digital Source 3 17th February 2014 07:50 AM
tweaking marantz cd84 drews Digital Source 21 20th March 2012 04:38 PM
Marantz CD84 diyman Digital Source 2 22nd November 2006 04:59 PM
Marantz Cd84 chasbmwe30 Digital Source 15 29th January 2006 12:12 PM
Copyright ©1999-2017 diyAudio
