| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 |
Banned
Hi Bas,
To avoid all confusion picture is attached. As a hint the direct coupling of the AD8561 to the CS8412 gave a huge improvment.........Jocko knew it all along |
#23 | |
In the meantime I also switched from inverting amps to non inverting (GC amps, that is). Just when I thought that my modded Marantz CD-94 was all I could be getting from my current digital setup, just for a fun of it (or actually, because I found buyer for my "simple" DAC) I tried it out by connecting to the CD-Pro. Initially, before warming it up, it sounded like nothing special, but when I checked it out after few hours, I was pleasantly surprised. It presented the music with some sort of harmony that other setups simply didn't. The "small" DAC was very natural and coherent and let me enjoy music actually more than the more elaborate setups. I am still puzzled by that, but plan to investigate it further. I did also try 8V PS (with output resistors suggested by Fedde) and while this DAC sounds different than the one with 5V supply, it may be also appealing. The difference in sound between 5V and 8V supplies is very similar to the difference between inverting and non-inverting GC amps. Those who tried both, will know what I mean ![]() The "small" DAC is definitely better than the bigger one. It is almost on level with modded Marantz. The Marantz has more refinement and detail, but I'm still not completely sure if it sounds as natuaral as the "simple" one. |
#24 |
Thanks guys,
i will start with the monkeyfilter for now. i read where some guy said replacing the 8412 with cs8414 would give improvements, Anybody believe this? they seem to spec out the same except for kHz. cheers |
#25 | |
As far as I know the 14 is a shrink of the 12 Ciao |
| need amp suggestions please. | kendt | Tubes / Valves | 14 | 23rd February 2009 01:13 AM |
| First DIY. Suggestions are welcome. | RomanSivers | Multi-Way | 3 | 19th December 2006 04:29 PM |
| SET Suggestions | nogoodboyo | Tubes / Valves | 37 | 11th March 2006 08:38 AM |
| need suggestions please.. | oface | Full Range | 2 | 23rd March 2005 04:46 AM |
| Any suggestions | jaybird | Multi-Way | 3 | 15th January 2004 09:12 PM |
| Page generated in 0.08610 seconds (85.53% PHP - 14.47% MySQL) with 11 queries |
