Yamaha CDC-765 Skips First Three Songs on Disc - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th February 2015, 11:27 PM   #1
Default Yamaha CDC-765 Skips First Three Songs on Disc
My 5 disc player has started to skip the first three tracks on the CD, doesn't matter which disc it is. Any ideas as to where I should start looking to solve the problem?
Old 18th February 2015, 07:04 AM   #2
Mooly's Avatar
Never worked on one of these but checking the sled assembly would be a good start. Make sure its free and that there is no old/hardened grease on any gears related to the sled.
Also check the RF quality with a scope. That should be part of any basic first test on a player.
If you can find no obvious reason then monitor the sled drive voltage during play. If it climbs steadily and then drops back as the sled jerks and skips forward then that's a good sign of mechanical problems (sled not free)
Installing and using LTspice. From beginner to advanced.
Old 18th February 2015, 04:27 PM   #3
The sled definitely jerks and skips forward when playing, I saw this when I had the cover off watching what it was doing.
Old 18th February 2015, 06:48 PM   #4
Mooly's Avatar
First steps then would be to confirm that the mechanics are 100% OK. That means removing and dismantling the sled assembly and cleaning it all up and relubricating with a suitable grease (I've never worked on one of these so can only give general advice). Old grease can harden, get contaminated, or deteriorate and get what are like small granules forming in it... these cause the small gears to jam momentarily, when the servo increases the drive then the sled jerks forward.
There may be other issues at work but you have to confirm the mechanical side of things is good first.
Old 18th February 2015, 07:54 PM   #5
Ok, I will remove the sled assembly, clean it up and re-lube. Any recommendations on the type of grease I should use?
Old 18th February 2015, 09:57 PM   #6
Best way I've found is to use a bit of IPA (isopropyl alcohol) on a cotton bud for cleaning, then re-lube with silicone grease as this won't harm plastics/rubber. Don't use mineral oil or grease based on this. I've not worked on your make of cd player, but my Marantz has had the same problem in the past and it's down to old/dried grease building up on the slider rod that the laser tracks along.
Old 18th February 2015, 10:03 PM   #7
I will give it a shot and report back. The player is 19 years old and probably has never been serviced by the PO.
Old 19th February 2015, 06:37 AM   #8
Mooly's Avatar
The stuff I use is a special plastic/metal compatible grease,
Contact Lubricants - Other - Special Plastic Grease - SPG | Electrolube
Silicon lubes are fine as long as they are not to sticky and viscous.
Last edited by Mooly; 21st February 2015 at 06:52 AM. Reason: Not added. Should read not to sticky
Old 20th February 2015, 07:19 PM   #9
Well I took the case off today and it looks to be a tracking issue with the horizontal toothed unit attached to the eye. As it tries to play the first track, the noise I am hearing is the gear on the right side teeth slipping as it is trying to move left, but hits a square clear plastic button below the metal frame. The square button is spring-loaded from what I can tell. Sorry, I don't know the technical names for these parts. So I presume that there is an alignment issue?
Here's a picture of what I have been talking about
Old 20th February 2015, 08:00 PM   #10
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Make sure the teeth are clean and don't use any lubricant as they are made from self lubricating plastic. You will probably find, knowing this assembly, one of the teeth is bent or there is some fluff/debris on the feed cog.
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Yamaha CDC-685 5-disc CD player/changer GTDS Swap Meet 0 16th February 2014 08:00 PM
Help tweaking a Yamaha CDC-655 Hewie Digital Source 1 18th February 2011 09:03 PM
yamaha cdc 635 SS64 Everything Else 2 14th June 2010 11:22 PM
Yamaha CDC-615 DAC question.. Big_Bill Digital Source 4 23rd September 2009 03:33 PM
Philips CDC 935 always too sensitive - skips often onyaw Digital Source 1 24th January 2009 09:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
