DAC MSB adjustment - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th February 2015, 05:03 PM   #1
Default DAC MSB adjustment
Hi there
I succeeded in MSB adjustment of PCM58P with pretty good results.
Now I would like to go further and adjust bit2, bit3 & bit4 too.
I'm not very smart with digital audio and i'm not sure how to proceed.
Should I adjust each bit alone with the others disconnected.
Should I begin with bit4, then bit3...MSB ?
Reverse order ?
Old 17th February 2015, 08:12 AM   #2
This tool should help:
DAC linearity test CD
Old 17th February 2015, 05:19 PM   #3
thank you lcsalzar but it doesn't help at all
Old 17th February 2015, 06:53 PM   #4
If you describe what you don't understand I try to help.
Old 18th February 2015, 07:44 AM   #5
I just don't see the link with my problem.
I explain myself.
In order to make the adjustment, I burned a CD with 3 minutes of 1KHz sinewave -30dB and put it into a CD player connected at the input jack of a PC sound card.
Then I used DSSF3 THD analyser (1KHz reference) to adjust MSB pin of PCM58P and get the lowest THD.
It worked great, the result on my HIFI system is now amazing.
Now I just want to adjust the 3 other pins, bit2, bit3 & bit3, trying to get a little more linearity.
That's the problem.
Old 18th February 2015, 08:50 AM   #6
I understand your problem. MSB adjustment will linearize at zero crossing. B2 adjustment will linearize at 1/2 full scale. B3 will linearize at 1/4 and 3/4 full scale, and so on. So you need a full scale dithered 1kHz test signal and an FFT analyzer. Adjust MSB then B2 then B3 then B4 for minimum spurious harmonics.
My linearity test CD method is a visual alternative, but one needs a measuring amplifier and an oscilloscope. Either method gives the same optimum.
Old 18th February 2015, 01:57 PM   #7
OK, whatever I get some questions, I like to fully understand things.
1) What does mean "will linearize at zero crossing. B2 adjustment will linearize..."
2) "3/4 full scale" you write, isn't rather "1/8 full scale" ?
3) "full scale dithered 1kHz test signal" : I found "http://www.wavecor.co.uk/testdisk.htmlfoundhttp://www.wavecor.co.uk/testdisk.html”
Is it OK ? Otherwise, where may I found such a signal ?
4) Why a FFT analyzer, not a DHT ?
5) Lastly, when adjusting one pin, does the 3 others need to be disconnected ?
Old 19th February 2015, 07:39 AM   #8
http://tube.fw.hu/lintest.zip no longer exists.
Do you know where I can find these files now ?
Old 19th February 2015, 11:47 AM   #9
The site closed, but I uploaded the tracks here:
You have to write them onto an audio CD.
Old 20th February 2015, 08:39 AM   #10
Nice, thank's
MSB MVC-1 8 channel remote volume control perceptionchanges Swap Meet 1 21st November 2014 06:50 AM
Need power supply for msb link iii dac rbwinterlink Power Supplies 0 7th April 2010 05:34 PM
DBX zonepro 1260 & MSB MVC advice pop4richard Digital Line Level 3 10th December 2009 11:45 PM
MSB Link III DAC - Frequency Lights fail to Illuminate! Anyone have the same issue? dtm1962 Digital Source 0 9th March 2008 07:39 AM
Any Idea for the MSB or I2S transmit??? hatasa Digital Source 0 11th June 2003 07:30 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
