| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
is it right that the pin numbers of the TL431 read 123 as the pins of a BC550 read CBE ? Is it right that the output voltage should be 5V independent of the input voltage when R1/R1 are 1k ? Does the TL431 need a minimum load current ? Bernhard |
#2 |
#3 |
I built a test circuit, the resistor to pin 1 is 39ohm R1/R2 are 1k.
Input voltage is 8V. I increased to 10V. Sometimes it is 7,6V output and sometimes 5V. If 5V then it depends on input voltage. Higher input = higher output. Maybe Ikilled that with soldering ? Never happend before. |
#4 |
The series resistors have to be calculated to provide enough voltage drop. This drop depends on the current draw after regulation. If the drop isn't correct, then you may be getting more than required 5V.
#5 | |
if the series resistor is too small, the 431 won't last long
#6 |
Thanks Peter,
I got a damn strange data sheet before... http://www.componentkits.com/dslibrary/TL431.pdf In the schematic that I use from K. Boehm ref =3, in the data sheet ref = 1 *ggg* Also in that data sheet most values are only a fat point Turned the TL around and it works now, 5,0007V with 0,5% resistors. Other question: What happens if this little thingy fails ? Will it take the S1 to hell ?
#7 | |
GuidoB |
#8 |
May be put 1W zeners everywhere...
| Please help me check,Can this dual power use tl431 and a op work well? | szcharle | Power Supplies | 2 | 18th November 2008 09:05 AM |
| What's really going on in that TL431 | jackinnj | Power Supplies | 3 | 6th May 2007 01:22 AM |
| help understand the TL431 | jarthel | Parts | 6 | 1st October 2006 09:09 AM |
| Tl431 | sparkle | Digital Source | 11 | 22nd February 2004 09:10 PM |
| TL431 sucks? | Bas Horneman | Parts | 2 | 4th November 2003 11:09 AM |
| Page generated in 0.09513 seconds (77.77% PHP - 22.23% MySQL) with 10 queries |
