Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th January 2004, 03:42 PM   #1
macboy is offline macboy  Canada
Default PCM1796 or DSD1796
Has anyone tried the new TI/Burr-Brown PCM1796 or DSD1796 yet? They are listed as pin- and mode-compatible with the venerable PCM/DSD1792, but are about half the price. They are so new that my favorite parts source, Digi-key does not even list the part number yet, but my samps arrived today. If they perform well, I may replace the analog stage in my SACD player (Sony SCD-CE775) with a new one based these, something I wouldn't have done using the DSD1792 because of the cost. (The SACD player currently uses DSD1702 PCM/DSD DAC with integrated I/V followed by NJM2114 op-amps).
Old 26th January 2004, 09:54 PM   #2
OK, so nobody here has used this DAC yet.
Does anyone have an opinion based on its specs, as to whether or not it is worth my time and effort?
Old 26th January 2004, 10:33 PM   #3
For only a few dollars, the same form factor (and trouble), why bother with the part which gives 10dB less dynamic range? After all, my AD1853 gives similar specifications and it is 8 or so years old. Your cost arguement does not cut it as the cost of the unit will be only a small portion of total costs unless you are really nifty with your hands (really small wires instead of professional PCB). There is of course the aprilog converters but hey converters are relatively cheap ...
By the way, the PCM1794 is much easier to implement unless you are a programmer.
Petter
Old 26th May 2004, 09:29 PM   #4
diyAudio Moderator Emeritus
Bas Horneman's Avatar
K&K audio are bringing out a DAC based on the PCM1794 soon!
They absolutely rave about it! Pricing to be announced soon...
So to answer your question....it is apparently very much worth it to try something with that chip!
Bas
http://www.audioasylum.com/forums/Ka...ages/2063.html
Replace DSD1796 with DSD1792 joonho75 Digital Source 0 30th March 2008 02:15 PM
My first DAC, CS8415/PCM1796 based DragosB Digital Source 6 2nd November 2006 03:58 PM
DIY DAC with BB DSD1796, and BB DIT4192? Htguy Digital Source 1 17th October 2005 01:23 PM
Page generated in 0.07012 seconds (71.40% PHP - 28.60% MySQL) with 10 queries
