Replacement Philips CDM3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th January 2015, 07:05 PM   #1
Default Replacement Philips CDM3
Dear All,
I know this is an old issue...and I apologize in advance (there are many threads but are more than 10 years old...).
I would like to kindly ask if anybody solved the problem and successfully replaced the CDM3 mechanism with a new type... There are mechanics nowdays from philips whose cost is around 20-30$!
My question is: except that a new mechanic will not fix into the holes, and the support and everything must be remade, is there anyway to electrically/electronically use (or adapt) a different mechanic (easily foundable on the market and at reasonable cost) into a transport that foresees the CDM3? Even if I have to rebuild the 2 cables (means not compatible pin to pin) but the signals must be the same...
I am talking about a Micromega Duo Transport. Attached pictures.
Thanks in advance,
Gianmaria
Old 28th January 2015, 07:17 PM   #2
Mooly's Avatar
I've never heard of this being done successfully (that's not say it can't be though)
There are some very real obstacles to overcome in this... the lens assembly and its servo are designed "as one" in that they have very specific characteristics. The servo has a 'frequency response' and this produces its corresponding 'bode plot' for the stability of the system taking into account the ballistics of the lens and the electronics of the servo. A similar situation arises for the platter... its inertia and the corresponding electronics it interfaces to. On a more basic level, the motor could be hall effect voltage or current driven or even a conventional DC motor. There would be some considerable interfacing to be done.
Pretty much anything is achievable, just don't under-estimate the task.
Installing and using LTspice. From beginner to advanced.
Old 28th January 2015, 07:44 PM   #3
poynton is offline poynton  United Kingdom
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
The only real option would be to use the CDM-4 though this may not be a "better" choice.
It may be possible to fit a CDM-9 though the engineering involved may be difficult.
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 30th January 2015, 03:55 PM   #4
Hello,
thanks for the answers!
I was thinking to build something with a new mechanic but at the point we are, I don't think it is worthy at all!
My experctise is no more than electorinc building, no projects..
My idea was to reuse the Micromega duo chassix and (some) electronic parts (buttons, display, power supply etc.) but I should have the electrical schematic, that I don't have.
Furthermore I think all the eproms are not fitting...
I have to live with it and wait for a day I will meet a CDM3 somewhere
THX again,
gianmaria
Old 30th January 2015, 06:06 PM   #5
poynton's Avatar
Sound Leisure CD Jukebox Series 3 Laser Tested Working | eBay
Old 30th January 2015, 07:31 PM   #6
Thank you poynton!
He will ship only to UK
Have a great evening,
Gianmaria
Philips CDM4/36 (new) and Philips CDM3 DAC2011 DIY HiFi Supply 7 7th April 2013 10:43 PM
Philips CDM3 laser mech famoz Digital Source 0 17th December 2010 05:26 AM
Philips CDM3 Steven505 Digital Source 0 26th September 2008 11:16 PM
Philips CDM3 Repair? PeteB-DET Digital Source 8 3rd May 2007 03:58 PM
Philips cdm3 jjh1425 Digital Source 14 10th January 2004 04:18 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
