| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi!
I have been searching the net to find the datasheet of the PE8001A dac in my Pioneer cd-player without finding it. Then I found the datasheet of the BB PCM1716 and both the pin layout and the internal block diagram is identical. http://www-s.ti.com/sc/ds/pcm1716.pdf Is the Pioneer dac just a PCM1716 with pioneer wrapping? I hope not, haven`t heard much good things about the 1716! Anybody know if this is the same chip? Thanks Tor Martin
#2 |
I think so but i have no proof. There are no differences that i can see at least.
Hjelm |
#3 |
Does Legato link not refer to the filter part of the conversion process rather than the actual DAC used? Same as what others call up-sampling. That's what I thought. The filter uses a Pioneer proprietary algorithm, aka Legato Link, for the up-sampling/interpolation and then feeds the ordinary DAC with that data. In the Hi-Bit version it simply means that the DAC chip is more than 16 bits...
UrSv Those who say it can't be done should not stop those who are doing it. |
#4 |
Hi!
Thanks for answering! UrSv and hjelm, you are probably right. The "High bit" chip in this player is a 16 pin dip chip infront of the dac. Pioneer was ahead of time and had this upsampling chip in way before everybody else started raving about it! I guess that the datasheet for the 1716 is valid for the Pioneer dac aswell. Thanks Tor Martin
| Problems with PCM1716 | blu_line | Digital Source | 0 | 30th June 2006 10:18 AM |
| replacing pcm1716 with wm8740 ?? | mekanoplastik | Digital Source | 12 | 10th August 2004 07:00 PM |
| decoupling PCM1716 | Smiffy | Digital Source | 6 | 6th February 2004 01:24 PM |
| PCM1716, is it any good? | mcai7et2 | Digital Source | 4 | 17th December 2003 04:36 PM |
| PCM1716 in differential mode | wmincy | Digital Source | 3 | 28th September 2003 07:55 AM |
| Page generated in 0.08039 seconds (76.52% PHP - 23.48% MySQL) with 11 queries |
