How can I connect differential signaling I2S to Single-ended I2S - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd December 2014, 11:23 AM   #1
Question How can I connect differential signaling I2S to Single-ended I2S
I have Gustard U12 Usb to I2S convertor and TDA1547 DAC (DAC7). The Gustard has a differential I2S HDMI output. The TDA1547 is single ended. Can you help me with schematic or advice?
Output I2S: DATA+, DATA-, BCLK+, BCLK-, LRCK+, LRCK-, MCLK+, MCLK-,+5v and GRND for each input, common GRND.
Input I2S: SCLK, SDATA, L/RCLK, MCLK, GRND (separate for signal and common GND).
Old 23rd April 2015, 07:22 PM   #2
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Hey, I need to know as well! I've got a Gustard u12 too.
Old 23rd April 2015, 08:02 PM   #3
Have a U12.
Bought a lvds-ttl converter like this
HiFimeDIY i2s/DSD Isolator 384kHz HDMI to TTL interface
Works like a charm
Connected to Soekris dam dac.
Old 30th April 2015, 08:35 AM   #4
Has anyone found a different solution?
Old 30th April 2015, 01:07 PM   #5
Sweet, thanks!
Old 30th April 2015, 06:37 PM   #6
Can you post some photos of your dac?
Old 1st May 2015, 02:58 PM   #7
I just bought that hifimeDIY I2S/DSD isolator.
SONOS ZP80, open and connect directly to I2S? superlian PC Based 4 29th January 2014 10:29 AM
Differential to single ended recommendation (PCM179x) sfasf Digital Line Level 20 20th March 2013 01:11 AM
TDA1540 to I2S connect vrpvrp Digital Source 6 18th April 2012 07:41 PM
single-ended to differential? gentlevoice Digital Line Level 16 17th December 2008 06:18 AM
Differential to single ended... Bas Horneman Tubes / Valves 21 2nd April 2003 02:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
