| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
There doesn't seem to be a thread here for collecting & comparing test results for sound cards & other audio hardware, so I thought I'd start one. Maybe it should be permanent, if it proves popular.
To kick off, here are my results for a M-Audio Audiophile USB ADC/DAC unit. These were done using RMAA 5.2 from http://audio.rightmark.org/ Attached are the 16-bit 48Khz results. Cheers IH |
#2 |
Here are the 24-bit. 44.1Khz results:
#3 |
...and the 24-bit 48Khz results.
For these tests, I looped the RCA outs straight back to the RCA ins; Rightmark complained that the input level was too low (-6dBFS or so), even with the output level control right up. It may well be, therefore, that you can get 6dB better noise floor if you get the input level high enough. I also had problems doing a 16bit 44.1Khz run; not sure why, as it records & plays perfectly well with other programs on these settings. Now to test the rest of my gear collection... Cheers IH |
| Zaph's latest test results. | ScottG | Multi-Way | 5 | 22nd May 2009 06:49 AM |
| nigc test results | squadra | Chip Amps | 3 | 9th September 2004 09:04 AM |
| TDA1543 test results using SpectraLab. | IpsilonSound | Digital Source | 28 | 23rd June 2004 10:59 PM |
| got my ESI WT2496 soundcard today - results :) | ergo | Digital Source | 3 | 30th October 2003 07:24 PM |
| Page generated in 0.07913 seconds (65.92% PHP - 34.08% MySQL) with 11 queries |
