Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd January 2004, 05:11 AM   #1
lgreen is offline lgreen  United States
lgreen's Avatar
Default CDPRO2- do you just add PS?
OK, after reading for endless hours here and on the web, it looks like that if you buy the CD pro2 module and the ready working display board, RC handset, center hub, connectors, disc clamp and suspension parts from here:
http://www.daisy-laser.nl/homeoptics/page25.html
all that is necessary is to add power supplies. Ok, and some kind of case.
Is this true? Seems too easy. Maybe this is why it cost so much, right?
I'm thinking about doing it so let me know if there is more. For example, I don't want to be designing any clocks or digital circuitry. But I would really hate it if I got that stuff and needed to add something other than a case and power supply.
Old 23rd January 2004, 11:29 AM   #2
Lovan is offline Lovan  Sweden
Lovan's Avatar
Send a message via ICQ to Lovan
Well if it seems to be to easy maybe you shouldnŽt be making one?
There are some complications. The psu is probably the hardest bit. And also you "need" a DAC.
Read some more endless hours and youŽll see what I mean.
Not meant to discourage you. By all means, buy one and build it but read up a bit more before
Old 23rd January 2004, 11:53 AM   #3
Coulomb is offline Coulomb  Canada
Coulomb's Avatar
Actually the CDPRO2 has it's own DAC.
It provides several outputs, Line Level L+R Audio, SPDIF, AES/BEU and I2s.
All you need is a power supply and a case to get it going, the P/S is a little tricky but Nico gives you all the information required to get it going.
Anthony
Old 23rd January 2004, 01:25 PM   #4
Lyra is offline Lyra  Norway
Lyra's Avatar
Anthony
How is the sound from the "buildt in DAC".????
24bit/96kHz isn't it ?
Some Philips DAC i presume....
Am considering one of this, but would apreciate to work/ pay on one thing at a time....
Lyra
Old 23rd January 2004, 01:33 PM   #5
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Building a working cdpro2 kit isn't hard at all, especially if you order the ready working board from Nico. There is a built-in dac in the transport, and a simple power supply can be made from a pair of regulators, a handful of caps (and transformer to power them). (i used a 7905 and a variable regulator for my first prototype). The new units have the 24bit dac, and the older ones have the 16bit dac.
If your goal is to build a solid, good sounding cdpro2 unit, this will take a lot more work. You will need to build a DAC for it, and more complex power supplies. There are also many considerations that I haven't considered yet.
I built a unit from scratch, making the control pcb myself:
http://brian.darg.net/cdpro2
My unit is currently in the working stage, and I have not had time yet to see how it compares to other units, and make it good sounding.
Brian
Old 23rd January 2004, 01:36 PM   #6
Coulomb's Avatar
Lyra
I have not run mine yet, but the new CDPRO2M has a newer DAC and is supposed to improve on the sound quality.
Anthony
Old 24th January 2004, 02:05 PM   #7
wazzup is offline wazzup  Netherlands
Send a message via MSN to wazzup
I think the build in dac is quite decent. It sounds better then some stand alone dacs I heard.
"I`m not the messiah!"
Old 24th February 2004, 09:48 AM   #8
Herdi is offline Herdi  Poland
Send a message via ICQ to Herdi
Hello Sorry every body for my English
Brian where i can buy this same display whu you have at your cd player
How to reclock CDPro2? cartman Digital Line Level 1 5th May 2009 07:52 PM
DSA protocol for CDPRO2 billr Digital Source 3 4th April 2005 09:17 AM
philips CDPRO2 Joules Digital Source 4 12th January 2005 08:06 PM
EIJ on CDPRO2 DonJuan Digital Source 8 17th February 2004 04:09 AM
Page generated in 0.10424 seconds (78.24% PHP - 21.76% MySQL) with 10 queries
