AD1865 DAC Transformer alternatives - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th December 2014, 09:11 PM   #1
Default AD1865 DAC Transformer alternatives
I know sowter is offering some transformers for current output DACs but they are too expensive for experimenting.
So here we are, has someone used something else? I am looking at cinemag CMOB-3 and CMMI-8B3 for example....
Old 12th December 2014, 03:14 PM   #2
oshifis is online now oshifis  Hungary
Lundahl - but they are not cheap either.
Old 12th December 2014, 03:44 PM   #3
I built my NOS AD1865 using the best parts i can afford. Using the sowter 9545 with OOC wire no less together with rhopoint passive i/v resistor to a tube output. The sowter 9545 is use as a balance to single but it can also use as balanced out.
No regrets...
Old 12th December 2014, 04:25 PM   #4
I don't know of any hifi quality (amorphous or high nickel core) line level output transformers that could be characterized as cheap. You could save some cost, without quality sacrifice, the lower is the output impedance of the driving circuit, and/or the lower is the maximum trnasformer signal amplitude. Those two parameters greatly determine the cost of an audio transformer.
In your specific implementation, the passive I/V ressistors will mostly determine how low the driving source impedance will be. However, because you are using an active output stage (I'll assume it provides voltage gain) you should be able to find cost savings due to a maximum required undistorted transformer signal level that's reduced by a factor equal to the active stage's gain - compared to a transformer designed for direct line level output.
Ken
Old 12th December 2014, 09:22 PM   #5
Thank you for the info guys...I am aware of the fact that good stuf costs more money but
this thread should deal whit the dilema of finding cheaper solutions to experiment whit and
maybe sound similar....
On ebay there is something like this available: ST-20600-OB
Also from edcor maybe something available or as I pointed to were the cinemags...
Old 12th December 2014, 11:40 PM   #6
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
I wound my own DAC output trafos using ferrite PQ cores. Price of parts - around $2 each, lots of labour time though.
Seek not the favour of the multitude...rather the testimony of few. And number not voices, but weigh them. - Kant
The capacity for impartial observation is commonly called 'cynicism' by those who lack it.
Old 13th December 2014, 01:13 PM   #7
Perhaps, then, the first issue to be addressed is why exactly do you want to employ transformer coupling of the AD1865?
Ken
Old 13th December 2014, 01:36 PM   #8
This way its better isolation from DAC to the output circuit,
also you get a step up of signal...I used only tube output stage and it wasnt the max what I
expected...I also tried a simple Jfet stage whit mosfet source follower and it wasnt bad at all
but something is still missing...
Old 13th December 2014, 02:56 PM   #9
donovas is offline donovas  South Korea
how? i want try
Old 13th December 2014, 03:13 PM   #10
abraxalito's Avatar
Happy to oblige - what voltage levels do you want to interface? Then I can suggest particular cores and wire gauges and numbers of turns.
DAC-END 24 (AD1865 NOS DAC ) quanghao Quanghao Audio Design 4 14th December 2014 11:42 AM
DAC-END The best DAC AD1865- UPDAT 2011 quanghao Quanghao Audio Design 201 8th December 2014 06:02 PM
AD1865 the best DAC audiodesign Digital Source 352 17th November 2013 05:08 PM
FS: AD1865 tube DAC (DAC END) tassosk Swap Meet 7 13th October 2012 01:17 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 08:03 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
