diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   DC-DC converter to get +-12V to feed the ouput opamps in DAC2000 (http://www.diyaudio.com/forums/digital-source/26547-dc-dc-converter-12v-feed-ouput-opamps-dac2000.html)
Ryssen 21st January 2004 08:16 PM
I have a 7,2v accumulator,and if I use the IC MAX743 DC-DC converter to get +-12V to feed the ouput opamps in DAC2000,
Will the switch frekv. diturb the audio output?
MAX 743:http://www.maxim-ic.com/quick_view2...._pk/1344/ln/en
mcs 21st January 2004 09:28 PM
You could also considder using a standard DC-DC converter. Like this one from Elfa: http://www.elfa.se/elfa/produkter/dk/2017321.htm
But either method will probably cause noise, so a metal shielding can will probably be a good idea. You should probably also add extra voltage regulators to remove noise/ripple after the converter...
Best regards,
Mikkel C. Simonsen
jean-paul 21st January 2004 09:37 PM
You maybe don't want this advice but:
You could use 2 accumulators or even better, a decent transformer with a decent linear supply.
Don't expect much from switchers, they loose from linear supplies in terms of noise and they radiate RF in most cases ( certainly DIY switchers I might add ). Very hard to get them quiet and knowing that they will practically never be as quiet as good linear supplies I gave up trying.
Benjlv 21st January 2004 10:14 PM
could you explain your desired application a little more. I may be able to recommend another solution.
in general the inductor based power converters throw a lot of eletromagnetic noise around as a part of their function. This creates noise and thats no good. So unless you are able to keep the circuit away from the DAC or shield it very throughaly i would suggest finding another solution.
Ryssen 21st January 2004 10:45 PM
I have a 7,2Volt accumulator and charger in my CD player that powers all +5v
in the cd(Pioneer pds 904)I have removed the trafo for +-12v,as
I have been using a tubeoutput stage,now I am building a Ext. DAC2000.I thought of powering the output ICīs in the DAC with
the 7,2v, but the opamps will not run on single + power(or will
they?)I thougt if I used a +- converter I got +- 12volts,and even
+- 5volts for the Dacīs.So the 7,2volts is in the cd player,what if I
put the converter in a shielded box?
hifi 21st January 2004 10:54 PM
Does the dac need to be portalbe or why the desire to have it powered frome one 7,2v battery?
mcs 21st January 2004 11:02 PM
I have another application but the same problem, so I would like to hear your recommendations. My application is an SSM2019 mic. pre. that needs +/-12V or so. I need to power it from a 6V battery, so I was also planning a DC/DC converter. But if you have better ideas?
Best regards,
Mikkel C. Simonsen
Ryssen 21st January 2004 11:10 PM
No,I thougt I got cleaner DC from battery,when I already have it in my CD player.Or whats your solution?
hifi 21st January 2004 11:22 PM
"No,I thougt I got cleaner DC from battery,when I already have it in my CD player.Or whats your solution?"
No you wonīt a simple linear supply will most likely give a much better result,
Why not just get 2pcs of lead batteries?
/micke
V/IR 21st January 2004 11:36 PM
A DC/DC converter in a mic. amp is a real challange - but they used in professional phantom 48v boosters.
The biggest two problems are (1) the fast transients that you get with most modern current-mode switching regulators (2) the HF magnetic leakage from the switching inductor.
The fast transients can be dealt with by slugging the inductor switching with a capacitor this will affect the eff% of the converter but will help the transients. Using magnetically shielded inductors will reduce noise. Best would be to mount the DC/DC in the far corner of the enclosure in it's own electrically screened box with PI feed-thru filters on the inputs and outputs.
The other approach that gives a good noise figure and *no* inductor is the charge-pump. These are simple to build and will run at a fixed freq. AND duty cycle; you will need to re-regulate the outputs on these supplies - this would be great for +/-12V from 6V.
Resources saved on this page: MySQL 18.75%
