| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I bought an used Philips DVD-711 with ZAPFilter Mk2, and XO2 already installed.
The sound is quite (very!!!) good.... ![]() My plan was to remove this (LCAudio stuff), and mount it in another CDP i own, and want to use as CD-player. The ZAPFilter is easy-removable, but if I remove the XO2 the DVD player have no clock, and will be DEAD !! I want to use the DVD-player as an standalone DVD player (not connected to my main sound system), and would apreciate something about how to mount a x-tal, and the apropriate cap's the way it was in the originally player......(don't have schematics regarding this player) Don't think there would be any point in a low jitter XO2-clock, when it is used as a DVD-player only!?. Can anybody help me....pleeeeaaaaase ? Lyra
#2 |
Here is a picture of where the x-tal should be.
On the picture there are some wires coming from the XO2 (now removed...). It seems like a resistor in paralell with the XO !? Think this too should be removed. Is there a (easy) way to use an ordinary (non SMD) x-tal here ? Can't see any cap's missing, or any signs of soldering exept where the x-tal should be. The original x-tal seems to have been a SMD x-tal with tree legs !? PS: I don't need a low jitter clock in this player, just want it to work.....or is there anybody who have this particular "original" x-tal ?? All the best ! Lyra |
#3 |
You will most likely find that the Crystal on the X02 board you removed is 27MHz - this is the most common DVD Master Clock Frequency. If you wish to fit the X02 board to a CD player, you will have to change this Crystal to match your CD players operating Frequency.
As the SMD “foot print” in your DVD player has 3 Pins, it’s most likely that the original Crystal had in-built Capacitors – somewhere between 10pF to 33pF - most likely 22pF. It would be better to try and source the original crystal, if not then a normal 2-pin type can be fitted, by adding 2 external capacitors. These Capacitors (x2) need to be fitted from both end pads (the outer most pads) to the centre pad (which is Ground), then a 27 MHz* crystal fitted across the 2 outer pads. *First, confirm that the original Crystal was 27MHz – as fitted to the X02 Board. |
#4 |
Lyra: If you send me an email with your details, i can most probably find one of these 3 pin xtals for you.
#5 | |
I used the crystal from the XO clock, and two caps lying around (marked n22 !?). It is working now !!
#6 |
I'm amazed it works - while the connections are correct, the caps are 220pF and not 22pF - for sure the frequency will be totally wrong, but if it works - it works!
| lcaudio`s LN regulator | Mikewong | Solid State | 1 | 31st January 2009 06:54 PM |
| LCaudio fraud? | ackcheng | Class D | 11 | 30th August 2006 11:05 AM |
| LCAudio Softstart | chrisb03 | Class D | 4 | 11th April 2005 05:54 AM |
| LCAudio XO2-Clock | Lyra | Digital Source | 15 | 20th January 2004 12:17 PM |
| Sony SA50ES used as drive - lcaudio clock useful ? | TNT | Digital Source | 22 | 13th January 2004 07:55 AM |
| Page generated in 0.09225 seconds (76.94% PHP - 23.06% MySQL) with 11 queries |
