Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Recommend an old CD player with very good transport?
Old 18th January 2017, 08:53 PM   #11
Ivo-Cici is offline Ivo-Cici  Macedonia
Ivo-Cici's Avatar
Send a message via MSN to Ivo-Cici Recommend an old CD player with very good transport?
For sure CDM 1 mkII mechanism...
Maybe best many bay is Philips CD880???
Ciao
Ivo-Cici
Old 18th January 2017, 09:21 PM   #12
TNT is online now TNT  Sweden
Sony 50ES
More distortion to the people!
Old 19th January 2017, 05:46 PM   #13
Salar is offline Salar  Germany
Just bought four CDM-1 based Philips from a house cleareance sale.
Really in a bad shape, the seller told me they were stored in a cellar. Thin black dust (I assume coal) and so much moisture that the bottom tin plates did rust to a dark grey. Even the cast aluminium of the CDM-1 has corroded with a rought white layer. First time I did see a black stain on a cotton bud when cleaning a lens.
But testing error correction with Digital Recordings "CD-Check",
one of those four players plays the highest error sizes (4x1.5mm - 6mm total)
without any clicks. None of my other players is able to do that. (but the other three CDM-1 based players fail as well). Because every CDM-1 has to be aligned in the factory (horizontal position, height and vertical angle) the sweet spot might be rarely achieved to allow perfect readout. But this is my assumption. Maybe less of an assumption:
The CDM-1 (and swing arm in general) uses only one horizontal servo. All other designs use two - one for coarse movement (the whole laser) one for the lens (fine movement).
I assume, when an big error (i.e gap in readout) appears, both servos will never be congruent - the laser loses track thus extending the gap. But with the swing arm, the laser
will be "stuck" in position. But as I said it is an assumption.
The four players are two Philips CD-104, one CD-304, one CD-304MKII.
The CD-304-MKII provides digital out, maybe the first Philips player to do so.
But servo design of all 4 players is identical.
They are all built like tanks, even though the design looks mediocre.
I mentioned the tin bottom plates, one could also take the chassis for plastic
but it is dull black painted die cast aluminium. Seek times are very slow btw,
I first thought this was an error. This also gives a remembrance why Philips lost many shares to Sony. With Sony, no tin plates and seek times of one second - to the last track. (Using BU-1 based mechs)
Also the trays age They will become stuck.
But still I would also propose a CDM-1 based player besides one fact:
The laser diode (Sharp LT022MC) is now 33 years old and will not last forever.
This is why i bought four of them, to find out wether the diode can be replaced. If this could be done, a CDM-1 based player would become an ever lasting transport:
Ball bearings, brushless motor, glass lenses. Besides the integrated circuits, everything can be replaced.
All the best,
Salar
Old 25th January 2017, 11:12 PM   #14
apoopoo999 is offline apoopoo999  United States
If you want to get creative you can pull the guts from a CDM4 player (I found several on ebay for $50-$100) and make a top loading unit. You can buy the top loading parts from taobao or aliexpress for dirt cheap.
Click the image to open in full size.print screen windows
Click the image to open in full size.photoupload
Old 26th January 2017, 01:23 AM   #15
Crankenfine is offline Crankenfine  United States
Thanks for the suggestion but I think I'm looking for a complete player, not really into building them.
Old 26th January 2017, 04:38 AM   #16
Hi!
From where exactly did you get the top loading parts and stabilizer?
All the best,
Salar
Old 26th January 2017, 06:04 AM   #17
Old 26th January 2017, 08:34 AM   #18
lcsaszar is offline lcsaszar  Hungary
Is there any project for contolling the Philips CDM-1 transport by a custom built controller + servo + display, not using the original CD player circuit?
Old 26th January 2017, 09:48 PM   #19
@icsazar to my knowledge not yet. Would like to develop one, but my
technical abilities are zero.
@apoopoo999
Thanks a lot for the links (in my browser they are displayed as question marks)
but online translation does not work, the text is not displayed.
Old 29th November 2017, 03:27 AM   #20
BillWojo is offline BillWojo  United States
apoopoo999, if they would sell those top loader chassis as a kit minus the laser transport at a decent price, it would be a big hit. I would love a cool looking top loader but I don't have the skills to do the electrical end of it. Someone should get a kit together and market them.
BillWojo
Recommend an old CD player with very good transport?Hide this!Advertise here!
CD player for use as Transport hifiknutter Digital Source 0 27th February 2010 02:16 PM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 08:12 PM
CD Player vs. CD Transport using CD-PRO2 module tomchaoda Digital Source 27 22nd May 2004 08:29 AM
Portable CD player as a transport !? GregGC Digital Source 5 30th January 2004 02:44 AM
Which CD player is better as transport? macsaif Digital Source 0 20th November 2002 10:58 AM
