Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th January 2004, 01:41 PM   #1
Question SACD player Op-amp questions!
Hi there, I just bought a Sony NS685V sacd/dvd player and of course I have opened up the lid to look for possible mods, the analog output board uses "ST C4558" op amps and 47uF output caps on it (electrolytic), the C4558 is a dual bipolar op amp in a SMD package.
My questions are, is the Burr Brown 2134 dual op amp a direct pin for pin swap? I have checked the PDF data and it looks to be, but what about offset voltages etc? I am not an expert so any advice is appreciated, I have all the de-soldering tools and SMD tools at work for the swap.
My other queastion is, what would you suggest swapping the 47uF electolytic output caps to? 47uF seems quite high, would I get away with less? If so I can get my hands on plenty of WIMA polypropylene caps to swap them with, would 3.3/6.6uF be too low?
Thanks again folks for your advice!
Chris
Old 19th January 2004, 01:45 PM   #2
Default Re: SACD player Op-amp questions!
Yes, no problem
Use 47 uF BGN
Old 19th January 2004, 02:18 PM   #3
Wink Thanks
Use 47 uF BGN
What exactly is a BGN? is that the type of cap or the brand? I had a look on digikey but I didn't see anything.
Thanks!
Chris
Old 19th January 2004, 02:48 PM   #4
Default Re: Thanks
Originally posted by bart_dood
Use 47 uF BGN
Thanks!
Chris
Black Gate N type (non-polar) from Michael Percy or Parts Connexion.
Old 19th January 2004, 03:32 PM   #5
eganz is offline eganz  United States
Or from Reference Audio Mods ...
These are very high quality electrolytic capacitors suitable for coupling applications.
Old 19th January 2004, 04:16 PM   #6
Yeah, get the 6.3V, 47uF Black Gate NX Hi-Q (non-polarized) caps.
If you use partsconnexion, it is item number BLKGATE- 60206 ($2.55 each).
I really like these caps for output decoupling purposes. As far as going lower than 47uF, it depends on what the rest of the circuit looks like. You 'may' lose low frequency bass if you go lower, but like I said, it depends on how the output stage is configured (in terms of R, L, and C components).
Old 20th January 2004, 08:23 AM   #7
rbroer is offline rbroer  Netherlands
rbroer's Avatar
Default Re: Re: SACD player Op-amp questions!
Originally posted by fmak
Use 47 uF BGN
Hi Fred,
I don't get you
For someone stating being able to hear directionality of resistors , your advice for BG-N as coupling cap is quite strange. IME it's just ok and gives one a hifi-ish sound, but not more than that, not even when using two anti-parallel.
And I do not hear directionality of resistors
There are quite a few more transparant and neutral caps out there, see the numerous threads on these forums.
Rudolf Broertjes
Old 20th January 2004, 12:42 PM   #8
Default Re: Re: Re: SACD player Op-amp questions!
Originally posted by rbroer
Hi Fred,
I don't get you
Put this in context; probably the best choice for his situation. The BGNs take a LONG time to break in and are better than other lytics I know. If you like ANALYSIS then BG-FK.
There is no reason to spend e100s on a basic SACD.
Looking for new player SACD/DVDA is a must! Dougie085 Digital Source 8 27th July 2007 05:04 AM
does anybody have a JLTi SACD Player kensell21 Digital Source 0 21st June 2006 06:26 AM
Sony SACD player Vivek Digital Source 6 28th January 2005 04:12 PM
Is it possible to modify a US DVD/SACD player? m.parigi Digital Source 3 17th November 2004 11:46 PM
Page generated in 0.11586 seconds (79.33% PHP - 20.67% MySQL) with 10 queries
