| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello,
does somebody know the voltage on pin 1 of 6922 in AudiNote DAC Kit 1.2 ? (Voltage A and Voltage B on attached schematic) Thanks Pascal |
#2 |
Anode voltage for this SRPP configuration should be around 200V 180V will be fine. You don't need the 2k/2W resistor, so both voltages are the same. If you insist having 2k resistor than first calculate (or look the characteristics) the DC current through the tubes. Add this current with the current over the voltage divider (180V/200kohm), multiply it with 2k and you will get the voltage drop across this resistor.
Jan |
#3 |
Thank you very much Jan
Best Regards. Pascal. |
#4 |
Hello,PTSOUNDLAB.Could you send me the AudiNote DAC Kit 1.2's schematic?
Thanks. E-mail:mc_wilson@21cn.com
MC_Wilson |
#5 |
Hello Audionline,
I have tried to send you the mail but I have a return "user unknow". Are you sure your mail is correct and accept big attached file ? Pascal. |
#6 |
Dear PTSOUNDLAB,
You don't mind to send me a copy of the schematic as well. Much appreciated. Regards, Joe Ling My email : joelingNO@tm.net.my - remove the "NO" to mail me |
#7 |
Hello,
I'm sorry but the file is too big for your mails. You can download it here http://ptsoundlab.jexiste.fr/depotimg/kit12.exe . I will remove it in one or two days, so download it now ![]() Cordially Pascal. |
#8 |
Thanks !
Regards, Joe Ling |
#9 |
Hi,PTSOUNDLAB.
Oooo!My E-mail box is full,Sorry,Can you send it again?Thank you very mach... ADD:mc_wilson@21cn.com Why the file format is exe?
MC_Wilson |
#10 |
You can download from the link posted above.
It is a exe file because the archive is a self-extracting RAR Cheers Andrea |
| Audionote DAC or RAKK DAC | la1209 | Digital Line Level | 0 | 31st March 2009 12:47 PM |
| audionote 144 OPT comment pls... | calico88 | Tubes / Valves | 0 | 13th September 2006 10:02 AM |
| AudioNote DAC 4 SIG. | nafunga | Digital Source | 2 | 10th October 2005 07:44 AM |
| FS : Audionote SE tranny | cm | Swap Meet | 1 | 9th June 2004 06:12 AM |
| Transfomer Too hot on my AudioNote 300B kit one | audionote | Tubes / Valves | 7 | 6th November 2003 11:20 AM |
| Page generated in 0.10240 seconds (77.71% PHP - 22.29% MySQL) with 11 queries |
