Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th January 2004, 09:27 AM   #1
Send a message via ICQ to apolon34
Default 49.152mhz clock
hi,
i'm looking for a clock to build an oversampling dac.
I need 49.152mhz
i want low-cost and good-performance clock, so i'm looking for a pll or something like this.
The clock must work with 3.3v power supply (because all others chips i use are 3.3v)
i found the ics848-05c clock multiplier. It claims 25ps jitter and work with only a 2.048mhz clock.
it is good ?
do you know something better ?
Old 15th January 2004, 07:45 PM   #2
JohnW is offline JohnW  Hong Kong
JohnW's Avatar
Below is a 49.152MHz “Pierce” XO. If operated from a Very Low Noise PSU it will give sub 10pS Phase Noise Performance. It can be operated from 3V3 - you might have to tweak the component values, details below: -
It uses a trick I’ve only just come across – but apparently its commonly known. By reducing the value of the resistor across the Crystal in a Pierce oscillator, from the typical 1M to a value between 3K3 to 10K you force the Crystal to resonate at its third overtone.
C28 - Could be replaced with a variable Capacitor say 4-20pF to trim Frequency
C27 – Value dependent on Crystal – watch Mark-Space ratio and Frequency
Q12, Q13 MPSH10, BFS17 etc
If you find that the output oscillates at 16.384 (the Crystals fundamental) then try changing the value of R45 from somewhere between 3K3 to 10K.
Operate the XO from a clean supply – PSU decoupling not shown – use 100nF ceramics across power rails.
Old 17th January 2004, 04:06 PM   #3
hi,
thanks for your reply.
i'll try to build this on a test board.
Old 22nd January 2004, 07:09 PM   #4
hi,
i built that on a test board and i have some problems.
transistors used are bsx20 (should be equivalent)
the first part of the schematic (xtal, and first transistor) works well (i thought).
i can see a sinus at about 50Mhz (i can't mesurate it accurately) with some dc. (should be normal)
when i connect the 56pF capacitor and the second part of the schematic, the output at collector of the first transistor isn't sinus at all and at output, i have a ugly signal and the frequency isn't good anymore.
can i do something to improve ??
if i replace the second stage by a comparator, like ad8561, would it be better ?
thanks
Old 22nd January 2004, 09:37 PM   #5
JohnW's Avatar
Sorry!
After rechecking my circuit, pls. note the correct position for R45.
After checking circuit operation @ 3V3 I also changed C29 to 100pF.
With the transistors shown, the duty cycle is 48% - which is not bad, Rise and Fall times of 2nS, could be improved with a higher fT transistor for Q13, such as a BFS17.
The corrected circuit (note position of R45), for improved performance Q13 should be replaced with a BFS17. For 3V3 operation R49 could be reduced to say 240R for improved Rise times.
Old 23rd January 2004, 07:48 PM   #6
hi,
i made your modifications and that's not good yet.
on the output, i have a beautiful sinus signal with about 0.8v dc and 0.5v amplitude.
the frequency seems to be correct (about 20ns period)
the circuit is operating on 5vdc for testing.
Old 24th January 2004, 09:40 AM   #7
JohnW's Avatar
The Circuit is good, I have it working on the bench, try changing the transitor Q13 to a higher fT type.
Old 24th January 2004, 12:17 PM   #8
what transistor do you use as q13 ?
Old 24th January 2004, 12:31 PM   #9
Hi Apolon34,
maybe you have problems with your scope bandwidth or probe capacitance or compensation? You neeed 150 Mhz bandwidth scope&probe to see anything resembling 50 MHz square wave and 500MHz to measure it properly.
Best regards, Jaka Racman
Old 24th January 2004, 01:23 PM   #10
hi,
i have a 60mhz scope and probe.
scope have input impedance of 1M ohm // 15pF
the probe is ok with the square signal test of the scope.
i don't see a square, but a perfect sinus wave and the amplitude isn't ok (about 1.5v p-p) and about 1.6v dc
seems like if q13 hfe is too low to saturate the transistor.
i measured it about 80
maybe that's the base resistor value that is bad (1.5k) ?
My CD Clock - the "Kwok Clock" kwokm Digital Source 13 10th September 2006 12:34 PM
CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation stolbovoy Digital Source 7 3rd December 2004 07:18 PM
Audiocom clock vs. LC Audio clock KevinLee Digital Source 22 26th July 2004 01:29 PM
Kwak clock versus Tent clock rbroer Digital Source 22 21st September 2003 01:20 PM
Page generated in 0.10488 seconds (78.52% PHP - 21.48% MySQL) with 11 queries
