Error on Rotel RCD855 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th July 2014, 01:12 AM   #1
Default Error on Rotel RCD855
Hi All,
I have problem with my Rotel CDP855, hopefully you guys could guide me to make my player sing again.
I just changed a new old stock cdm4, but it still has the same problem, error reading disc/TOC.
Most of the capacitors have already changed, and some caps around ICs are changed from 47uf to 56uf.
The cdp play CD/CDR well before this,but one day, it just suddenly don't play, no warning or skipping & etc.
After a cd is inserted, the len swing and move up and down > then error shown on display > then the disc turn softly anti-clockwise for a while.
I adjusted the laser power & focus trimmers, no luck there.
I have read some threads here about same cdp with same error, but that did not solved my problem.
Thanks.
allen.
Old 25th July 2014, 08:33 AM   #2
The problem is probably in the focus circuit.
The sequence is as follows :-
1. Laser ON
2. Find focus
3. Spin disk
As the laser is moving up and down, the laser is on.
However, focus is not being found, hence no disc spinning.
Have you tried going into test mode.
The player is Philips based.
Kevin
Old 25th July 2014, 04:42 PM   #3
May I know I do I go into the service mode? press buttons 'pause' '<<', '>>' and 'repeat', and at the same time, press 'on' button?
Is there anyway I can adjust the laser focus to the right spot? I do not have the test cd or scope.
Thanks.
Rotel RCD-971 00 display error supernut Digital Source 43 4th May 2014 01:22 AM
Easy way to fry Rotel RCD855 - help needed aparatusonitus Digital Source 31 26th February 2010 01:19 AM
Marantz CD63 KI SIG, Error 12, Sled Error problem sisik Digital Source 1 9th November 2008 03:12 PM
Coupling Rotel RCD855 & Marantz CD52 Klimon Digital Source 4 18th July 2007 09:02 PM
Whats worse, 1db error in response curve or a phase error of 6? primalsea Multi-Way 5 13th May 2003 01:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
