WeiTone DeCode 4.0.1 - DAC Board (Dual ES9018 + Cyclone III FPGA) - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd July 2014, 04:40 PM   #1
NuTron is offline NuTron  Switzerland
Default WeiTone DeCode 4.0.1 - DAC Board (Dual ES9018 + Cyclone III FPGA)
Hi everyone
I found an interesting design of a dual ES9018 DAC. Unfortunately I couldn't get much information about the Board. Maybe take a minute to get a look:
FPGA软控的双并ES9018高烧解码-淘宝网
晚来的双并ES9018续_第二板 - Powered by Discuz!
I tried to get in contact with the seller, who also claims to be the designer. Although we couldn't realy communicate (I don't speak chinese, and google translate is a pain), he convinced me to be involved in the engineering process.
My first thought on this was; could the ESS Chips maybe be feed by a synchronous master clock from the Cyclone FPGA? There is a discussion on this forum and as far as I know Weiss used a Dice chip to implement a synchronous master clock in their 202.
I asked him about this, but I think there were too many missunderstandings, so I didn't get a satisfying answer... I know, without any detailed insights, one can probably only speculate, but what do you think? Does it make sense, that a Cyclone FPGA is used to generate a synchronous master clock?
Old 24th July 2014, 11:17 AM   #2
Just a small update. A closer look revealed, that indeed the MCLK is feed by the FPGA. Still I can't figure, if the master clock is synchronized with the bit clock (an exact multiple of it). I'll try to get in touch with WeiTone and ask again ... But anyway, what do you think of the board, is it worth a try?
Old 5th August 2014, 07:15 AM   #3
Do you know the register address of the ES9018?
The datasheet says REG#0 to REG#71. What I understand is the address is from
"0000 0000" (REG 0)
to
"1000 1110" (REG 71)
But it's not working
DAC-END R (ES9018) full assembled board audiodesign Quanghao Audio Design 2283 27th January 2016 03:46 AM
Low cost ES9018 DAC board GB syllable Group Buys 514 12th July 2014 02:23 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 08:13 PM
FS: NeoY2ks ES9018 DAC board with all the components guglielmope Swap Meet 4 18th December 2012 10:01 AM
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 08:50 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
