Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th January 2004, 08:31 PM   #1
mcs is offline mcs  Denmark
Default Multi-frequency clock
I'm looking for a multifrequency clock for my A/D converter (described in another thread).
I currently use a standard 12.288MHz xtal oscillator, but I need something that can generate all the standard frequencies (8.192, 11.2896, 12.288, 24.576 etc.) so I can record at difference samplerates.
Has anybody here made a circuit for that purpose?
This BB chip looks interesting:
http://focus.ti.com/docs/prod/folder...t/pll1700.html
Has anybody tried it?
Best regards,
Mikkel C. Simonsen
Old 12th January 2004, 09:25 PM   #2
Banned
Send a message via Yahoo to Elso Kwak
Cool Re: Multi-frequency clock
Best regards,
Mikkel C. Simonsen
Hi Mikkel,
You can use my clock that is the KWAK-CLOCK, connect all outputs together and enable each frequency with the Latch of the comparator. So for the four frequencies listed you will need four clocks.
The PLL1700 has too much jitter I believe.
Old 12th January 2004, 10:07 PM   #3
Default Re: Multi-frequency clock
[QUOTE]Originally posted by mcs
[B]I'm looking for a multifrequency clock for my A/D converter (described in another thread).
You can get a word clock generator for less. Swissonics WD8 at thomann.de is on sale for 200 euro. Generates 44.1 to 96, plus superclock.
Old 12th January 2004, 10:15 PM   #4
ukram is offline ukram  Finland
I have been dreaming about 21.168 MHz crystal, is there such a thing? (441 * 480) * 100 = 21.168M.
After learning the Xilinx stuff i could easily design EPLD chip that divides the necessary frequencies, as long as the main clock is not more than about 100 MHz, depending on the chip used.
Old 12th January 2004, 10:20 PM   #5
Default Re: Re: Multi-frequency clock
Less than what?
The PLL1700 chip only costs $2...
Best regards,
Mikkel C. Simonsen
Old 12th January 2004, 10:31 PM   #6
Originally posted by Elso Kwak
Hi Mikkel,
It looks interesting - but I think a bit too complicated for this purpose... As long as I use the A/D for recording, does the jitter matter? The data goes directly into a FIFO and on to a harddrive anyway...
But perhaps I should try one of your clocks in my CD-player
[EDIT]I just realised that the jitter probably does matter - but how much? Perhaps I should use a "good" clock for the main frequency, and a simple one for the rest...
BTW, how do you "distribute" the clock? I will need a clock for the A/D, the D/A and the playback circuit. Do you simply connect the loads in parallel, or do you need some kind of buffer?[/EDIT]
Best regards,
Mikkel C. Simonsen
Old 13th January 2004, 07:16 AM   #7
Default Re: Re: Re: Multi-frequency clock
[B]
Less than what?
Best regards,
When you add up the cost of high quality components, ancilliaries, power supply, enclosure, plus the amount of time in development and testing, it is cheaper to spend 200 euros as you can spend the time doing something alse!
Old 13th January 2004, 08:00 AM   #8
rbroer is offline rbroer  Netherlands
rbroer's Avatar
The PLL1700 is ok.
For better jitter numbers I suggest SM8706, SM8707 (used in better DVD players for example.
But to be honest, reading all these questions on very basic issues, you might seriously want to consider the solution FMAK posed in stead of doing something that might be over your head
Rudolf Broertjes
Old 13th January 2004, 08:18 AM   #9
Banned
Talking Re: Re: Re: Re: Multi-frequency clock
Originally posted by rbroer
The PLL1700 is ok.
Sandwich Ape Rudolf?
Sorry couldn't resist
Old 13th January 2004, 10:33 AM   #10
You can get a word clock generator for less. Swissonics WD8 at thomann.de is on sale for 200 euro. Generates 44.1 to 96, plus superclock. [/B]
The problem with this solution is that the WD8 is designed to drive a complete device as opposed to individual chips. The OP's ADC still has to have an internal clock system capable of locking to an external clock. That usually means a VCXO or two and a PLL.
ray.
clarion hxd 1 clock frequency? tomat Car Audio 4 30th June 2009 02:30 AM
Synchronizing Dem Clock on Multi 1541A Dacs jstang Digital Source 0 3rd May 2009 11:32 PM
Rotel 961 clock frequency jarek Chip Amps 2 27th February 2006 09:40 PM
Changing the clock frequency Pboden Digital Source 1 22nd January 2005 04:08 AM
1541 clock frequency Bernhard Digital Source 8 21st April 2004 11:17 PM
Page generated in 0.11664 seconds (80.19% PHP - 19.81% MySQL) with 10 queries
