Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th January 2004, 05:50 PM   #1
mcs is offline mcs  Denmark
Default AD1871 A/D converter
I have just built an A/D converter using the Analog Devices AD1871 chip.
It seems to work, but I would still like to know all the things I have done wrong
The schematic is here: http://stiftsbogtrykkeriet.dk/~mcs/ADCon2_sch.gif
And here is a small, blurry PCB drawing:
http://stiftsbogtrykkeriet.dk/~mcs/ADCon2_pcb.gif
I designed the circuit using the datasheet of the chip, and the evaluation board manual. I don't really know what I'm doing, as this is my first attempt...
Are the buffers and RC filters on the output a good idea? I copied those from the eval. board. And what RC filters (if any) should I use at the other end of the cable? Are schmitt trigger buffers a good idea on the input end?
I also might need an input selector to select between the A/D converter and a digital input. What do you use for switching between digital (I2S) signals? Analog switches/muxes? Relays?
Best regards,
Mikkel C. Simonsen
Old 30th June 2012, 06:34 PM   #2
Default Did it work
Just wondering if the circuit laid out actually worked.
24 bit 356 kHz DA converter martioz Digital Source 10 13th December 2004 08:01 AM
NEED DC to DC Converter sma Car Audio 3 16th December 2003 06:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
