Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
cs43122 tube output stage help - based on cdenhancer II design
Old 28th March 2004, 08:21 AM   #21
ackcheng is offline ackcheng  Hong Kong
Send a message via ICQ to ackcheng
Thanks everyone for your help! I have finally completed the digital section of my DAC and I am currently coming to the tube output stage with the 3a5 design! I am still a bit confused with the circuit schematic.
I am going to use one tub for each channel , is this correct?
F1 is connected to Pin 1 and F 2 is connected to Pin 7, correct?
What about pin 4? Does it need to be grounded? Or is it connected to the R7 (150) in the schematic?
Old 19th March 2006, 02:37 AM   #22
ACK2005 is offline ACK2005  Taiwan
Default SE tube buffer
A question:
I'm building cs43122 DAC recently.
If I use the 5687 version of output stage published in
http://www.ultranalog.com/cdenhancer/cdenhancer2.html
but with only a HALF configuration:
cs43122 AOUTL+ ( ignore AOUTL- !!) ==> 5687 ==> SE OPT .
Does this configuration still sound good?
cs43122 tube output stage help - based on cdenhancer II designHide this!Advertise here!
Badly in need of help on output inductor design for ZXCD1000 based 500 watts amp Razor_Edge Class D 27 17th November 2005 08:37 AM
12v tube output stage for cs43122 based dac? mbcouple Tubes / Valves 10 14th August 2004 01:47 AM
cs43122 output stage, something went wrong Thomas Giz Digital Source 5 31st October 2003 12:19 AM
cs43122 output stage Thomas Giz Digital Source 5 22nd October 2003 07:28 PM
Transformer in analoge stage in DAC (cs43122) hifi Digital Source 0 17th May 2001 08:02 PM
