Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th January 2004, 10:18 PM   #1
sparkle's Avatar
Question grounds in TDA1543 based dac
Dear all!
Is there any sonic difference if you group
analogue grounds to analogue and digital
grounds to digital or if You connect them
together in one ground (o.k. I know that they
are (at the end) all connected together but
is there any sonic benefit of grouping grounds and then
connecting them together beside that You avoide
hum that way and that sort of things).
Could anyone explaine this to me please?
p.s. I have made my prototip dac around one ground
and have no problems with hum or anythinf unusual.
So I am wondering am I missing something in
sound of it.......
Old 12th January 2004, 08:15 PM   #2
sparkle's Avatar
anybody
Old 13th January 2004, 02:34 PM   #3
ZERS is offline ZERS  France
The digital grounds and analogs one are qite different and the noise isn't the same.
Pratically, both must be shared on PCBs and the connexions between us must be done through a 100k (or more) resistor.
The "signal" within each of grounds has not the same nature and it's clear that the noise in the analog ground disturbs the digital part.
In terms of sounds, the sounds looks less clear.
Hope is help
Old 13th January 2004, 07:43 PM   #4
sparkle's Avatar
We'll try it and let You now- when I take a look on my pcb I have my grounds separated but connected with one tiny path with each other. I will cut that path and try with 100k in there to connect them
thanks
daniel
Old 13th January 2004, 08:58 PM   #5
sparkle's Avatar
Dear ZERS
I have separated all my digital grounds from analogue ones with 100k as U suggested. I could hear, in my speakers, that my dac was oscilating .
Turned down to 10k - oscilations were less to hear. Disconected the resistor- no oscilations. I will leave it separated with no resistor only connected with a tiny wire.
Best regards
daniel
Old 13th January 2004, 10:39 PM   #6
this is quite surprising. It must depe,d on the way the PCB is built.
Ispričavam se!
Old 15th January 2004, 11:02 AM   #7
guido is offline guido  Netherlands
guido's Avatar
General rule for DAC/ADC grounds:
Connect analog and digital gndplanes at the DAC/ADC, if not possible (more than one DAC, other reasons):
Connect analog and digital gnd pins to ANALOG ground.
Connect analog and digital together at the DAC/ADC as short track as possible. Any restistance between analog/digital would generate a voltage difference between analog and digital gnd pin.
Any voltage between those pins is then also present on the output!
Got this from an analog devices application note, together with the technical background. Not shure this applies for all DAC's/ADC's, check the datasheet.
E.g. this is stated in the BB PCM63, page eight
http://focus.ti.com/lit/ds/symlink/pcm63.pdf
So NOT the way elektuur did it in their first DAC.....
GuidoB
GuidoB
Old 15th January 2004, 07:54 PM   #8
sparkle's Avatar
Thanks- I was a little suspicious about that 100k resistor as ZERS and I have comented via mail but what a heck I give it a try to see what happens. It was not very nice to hear- as expected.....
daniel
My tda1543 based dac (as if there where not enough of them around ;o) hifi Digital Source 21 31st July 2012 03:25 AM
Differential TDA1543 based NOS DAC dsavitsk Digital Line Level 0 6th April 2009 06:41 PM
My TDA1543 DAC based on P. Daniel Design Algar_emi Digital Source 8 11th March 2006 02:12 AM
Looking for an active I/V stage for TDA1543-based DAC IpsilonSound Digital Source 21 17th June 2004 08:34 PM
tube buffer for TDA1543 based dac sparkle Tubes / Valves 11 25th February 2004 08:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
