Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Parallel DSD1794 NOS/DSD passive I/V
Old 16th June 2014, 02:51 PM   #1
2A3SET is offline 2A3SET  Canada
Default Parallel DSD1794 NOS/DSD passive I/V
Just for fun and sharing the experience, borrowed the idea from DDDAC1794 to run NOS mode to support 24/384K meanwhile also support DSD, worked out with PCB with DIPTRACE, doubt it's optimized, while looks better than P2P.
Old 16th June 2014, 03:03 PM   #2
Here is the isolator, clock buffer and reclocker board.
Old 16th June 2014, 03:05 PM   #3
Here is the final one, using BCF unbalancer to convert to SE.
Chord Hugo on the side.
Old 2nd October 2014, 04:11 PM   #4
stijn001 is offline stijn001  Netherlands
stijn001's Avatar
Impressive work. How did the Hugo compare to the dac you build?
Old 2nd October 2014, 09:27 PM   #5
PCM from Hugo is super also it drives my speaker directly,
Old 2nd October 2014, 09:48 PM   #6
I used to convert PCM to DSD using Jriver and feed the 1794, no need with Hugo as its at another level, Native DSD 1794 is more natural although noisier.
Parallel DSD1794 NOS/DSD passive I/VHide this!Advertise here!
DSD Playback system, DSF Player + USB DDC + DSD Amplifier KOON3876 Digital Source 116 4th September 2012 11:20 PM
NOS Mullard Double O EL34 NOS Pair Syl 6BQ5 EL84 vintagekind Swap Meet 3 30th March 2012 03:49 AM
winISD calcs: parallel vs series-parallel sadams Multi-Way 1 20th February 2011 07:45 PM
series Vs parallel passive Xovers Puggie Multi-Way 10 19th April 2005 04:06 PM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
Copyright ©1999-2017 diyAudio
