My WM8741 x 4 with DSD Project - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th June 2014, 07:15 AM   #1
Default My WM8741 x 4 with DSD Project
I got a WM8741 x 4 DAC main board and I2S/DSD card.
Now, I want to connect them in hardware mode, so that it can decoding PCM / DSD file which is smoothly selection by footbar2000
Old 14th June 2014, 07:19 AM   #2
ref. to wm8741 datasheet, in hardware mode.......
Pin 1, 2, 3, 5, 22, 27 are important source in.....
Old 14th June 2014, 07:29 AM   #3
ref. to I2S/DSD card, the spec. which provide from manufactory.....
Technical parameters:
Input: USB2.0, high speed interface
output:
1) S / PDIF 75 ohm coaxial output
2) I2S
support sampling rates (PCM):
1) 44.1 KHz
2) 48 KHz
3) 88.2 KHz
4) 96 KHz
5) 176.4 KHz
6) 192 KHz
7) 352.8 KHz
8) 384 KHz
sampling rate support (DSD):
1 ) 2.8 MHz (DSD64) (DoP, ASIO native DSD)
2) 5.6 MHz (DSD128) (DoP, ASIO native DSD)
3) 11.2 MHz (DSD256) (ASIO native DSD)
4) 22.5 MHz (DSD512) (ASIO native DSD )
support digits:
1) 32 bit I2S output
2) 24 bit S / PDIF
output compatibility:
Mac OS 10.6 or above, Linux, Windows 32/64 WASAPI, ASIO, KS, DS drive
recommended player: Foobar2000 etc.
Old 14th June 2014, 07:32 AM   #4
Beginning to connect both card, some idea need to consider.....
Old 14th June 2014, 07:33 AM   #5
to be continuous.......
Old 14th June 2014, 09:27 AM   #6
Nice project. What USB I2S/DSD board are you using?
Old 23rd June 2014, 11:18 PM   #7
That is Tanly usb to dsd board, i'm bought it from china market.
Tanly
Old 25th June 2014, 10:10 AM   #8
Tanly
Thanks, found it!
Old 26th June 2014, 09:21 AM   #9
hi hi, I'm come back....
Now, start from Tanly DSD USB board.........i can got the data output pins as shows on picture.
Old 26th June 2014, 09:43 AM   #10
Double check with WM8741 datasheet.......
I found that must need those data input.....
Let's go..... try to connect them.... hope it is work.
Wolfson WM8741 lduarte1973 Digital Line Level 33 18th December 2015 01:47 PM
FS: WM8741 ultrafi Swap Meet 2 12th March 2013 04:22 AM
Gain problem of DSD input to WM8741 DAC simonvan Digital Line Level 1 23rd December 2012 03:24 AM
DSD Playback system, DSF Player + USB DDC + DSD Amplifier KOON3876 Digital Source 116 4th September 2012 11:20 PM
WTB : WM8741 korben69 Swap Meet 2 23rd May 2011 11:37 AM
Copyright 1999-2017 diyAudio
