Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Audiolab 8200 CD left channel treble distortion
Old 12th June 2014, 03:26 PM   #1
andolink is offline andolink
Default Audiolab 8200 CD left channel treble distortion
Hi all,
For the last two days I've been getting a very noticeable metallic (tinny) sounding distortion in the left channel whenever there's a significant element of high frequency in the music like high lying violins. At first I thought the tweeter of my speaker was failing but switching over to my headphone rig where the only element in common with my speaker rig is the CD player, I get the same phenomenon coming through my headphone left channel.
Any ideas about what this might be? Any ideas about what to do about it?
Thanks in advance. (you guys have always been great about this stuff in the past!)
Old 12th June 2014, 05:04 PM   #2
Mooly's Avatar
That's a very strange problem.
First steps would be to try and identify what is going on by using a scope and a CD that displays the problem. Does any oscillation show ? Next up and it might be an idea to play a test CD (you can make one with Audacity) of a frequency sweep from 20 to 20kHz at 0db level and again see what shows on the scope distortion wise.
Old 12th June 2014, 11:04 PM   #3
The diagnostic testing you advise is beyond my scope (no pun intended). But thanks anyway for the suggestion.
Old 13th June 2014, 07:53 AM   #4
Mooly's Avatar
You do really need the test gear for work like this.
Without, and you need a circuit (or an ability to recognise and visualise the circuit from the board) and to then isolate and "swap" left and right as you work back from the sockets to see where the problem is.
Another idea is to probe the opamp outputs working back,and use AC coupled headphones and a series resistor to see if you can determine where the problem develops. You need to be careful doing that as connecting the 'phones to any point that has DC voltage will cause a loud crack or pop in the 'phones. So connect first and then listen
Old 15th June 2014, 12:46 PM   #5
I've pretty much come to the conclusion that the problem is not with my Audiolab CD player but with my left ear. Probably an earwax buildup. The treble distortion has been gone for the last couple of days anyway. This is a big relief because dealing with my ear is a whole lot easier and cheaper than with my CD player.
Old 15th June 2014, 01:19 PM   #6
Mooly's Avatar
Thanks for the update... hmm... yeah, maybe try some drops for a few days.
Audiolab 8200 CD left channel treble distortionHide this!Advertise here!
marantz pm 7200 left channel distortion chris212 Solid State 11 28th March 2013 04:15 PM
Cyrus2 amp Left channel distortion cslaw Solid State 14 7th March 2011 07:35 AM
strange distortion on one channel of cd player Luke Digital Source 13 18th December 2008 05:43 PM
CD players that have syncronized left and right channel soongsc Digital Source 13 4th March 2007 09:04 AM
left channel distortion mic_ael Chip Amps 6 17th February 2006 12:13 AM
