Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th January 2004, 05:07 PM   #1
wuffwaff's Avatar
Default Look for the mistake
attached you find the output stage from my Perpetual Technologies P3-A with crystal CS 4396 DA convertor (voltage output, balanced).
Besides trying to understand this (especially the second opamp) I would like to convert this to something with a passive filter, x-bosoz with ccs (like Henrik showed in another thread) and keep everything balanced.
Just for fun I was looking what filter frequencies are in this standard output and hereīs where the problem starts.
If I look at the first low-pass (1k, 5n6//1k) I īm already 2.6dB down at 20.000Hz, The second stage (499R, 1n5) ads another 0,7dB to this so Iīm down over 3dB at 20000Hz. Since this certainly isnīt the case I must be making a mistake somewhere in this (very simple) calculation
Can somebody point out what I am doing wrong?
Hereīs the calculation:
z@20000Hz = 1/(2PifC) = 1/2pi*20000*5.6*10^-9 = 1421 ohm
1421//1000 = 587 ohm
587/(1000+587) = 0,3699
20Log0,3699 = -8,64dB (attenuation by cap + halving by second 1k)
8,64 + 6 = -2,64 dB
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 9th January 2004, 09:11 PM   #2
sreten is online now sreten  United Kingdom
Well the first mistake I can see is your first lowpass filter.
The loop impedance seen by the bottom 5.6nF capacaitor to
ground is 1k||Ik i.e. 500R assuming zero sourse impedance.
sreten.
Old 9th January 2004, 09:13 PM   #3
The loop impedance seen by the bottom 5.6nF capacitor to
ground is 1k||1k i.e. 500R assuming zero source impedance.
Plug it into a circuit simulator.
sreten.
Old 10th January 2004, 07:40 AM   #4
wuffwaff's Avatar
sreten,
could you explain a bit more or do a calculation so I can see where I went wrong/how it is done? (I also assumed 0 ohm output impedance, otherwise the attenuation would be even bigger)
Circuit simulations are nice but donīt really help to understand how things work
william
Has any-one else made this mistake??? Moondog55 Multi-Way 15 3rd January 2009 11:31 PM
Rookie mistake?...Maybe... cjkpkg Tubelab 9 10th October 2008 10:01 PM
Help with a Small Mistake rhart Full Range 25 5th February 2006 07:50 PM
Page generated in 0.07015 seconds (74.10% PHP - 25.90% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
