| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
my D1 stage clone launched… The sound is just incredible. Extreme stability, neutrality and silence in the sound – maybe caused by the consequent CCS using. The schematic is a transfer from the P1.7 CCS into the pure D1 stage – thanks to the one and only! I have chosen the double JFET 2SK389 as converter. The sound is changing strongly with the bias current, find your own choice! Use for tests trimming resistors in the CCSs. I am still feeding this stage with just 0,1mA from my TDA1547 using 6,5k work resistor R_L and 680pF Filter cap parallel. But soon a pack of PCM1704 will feed this converter sweetie pie… Am I just to stupid or is there no way to upload attached files to the diyaudio server?! I have no web space installed so I can not refer to a personal www adress to lay down my pics somewhere. So please check the attached two links to see pics of the monster and the schematics… http://www.audiomap.de/forum/index.p...id=15097&page= http://www.audiomap.de/forum/index.p...id=15147&page= Tweaky regards Klaus |
#2 |
I'll do it for you. You should save the drawing as a picture and attach it here.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
I'm planning to try D1 stage with TDA1541A DAC.
Do you think using just the half of orignial (balanced) circuit without any changes to parts values would work ok? Bartek |
#4 |
It should work fine as it's not an X circuit.
#5 |
zygibajt,
I was thinking of doing the same but using 2 TDA1541 the way D1 works. Do you have any special reasons to use just 1 DAC chip? Regards |
#6 |
I have: it's a stereo DAC.
How do you plan to seperate into L & R channels?
#7 |
I have one reason ,too.
I'm playing with CD player,not separate DAC. By the way,I'm not quite sure I want to complicate things too much! All best Bartek |
#8 |
Peter,
I mean the second chip could be used to invert the phase. My idea was not splitting the channels. Do you think it's not possible with 1541? |
#9 |
I believe you can invert the phase in I2S signal, so the second chip is not required. You can of course do it with another chip as well you can use separate chips for L and R channels (guido was working on it), but such setups might sound different than doing it with a single chip.
#10 |
If one wants to recreate the Pass D1 with the TDA1541A a second chip will be necessary.
| F1 Clone DIY PCB | suds | Group Buys | 2 | 8th January 2009 09:50 AM |
| My F3 Clone | 04dgmsilv | Pass Labs | 11 | 31st August 2008 11:59 AM |
| clone AN/K | ccopp | Multi-Way | 0 | 9th July 2006 08:24 AM |
| Question regarding ProAc 2.5 Clone and Tempo 2 Clone | zoooh | Multi-Way | 5 | 11th March 2003 08:19 PM |
| Page generated in 0.10902 seconds (78.00% PHP - 22.00% MySQL) with 11 queries |
