Clock rates - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th May 2014, 07:24 PM   #1
scott wurcer's Avatar
Default Clock rates
I was surprised to see this much difference going from Maudio USB Duo to and external Fostex FR2LE field recorder. I have not traced where the difference is yet but the data going to the Maudio is the 1000.13Hz tone as shown, but the file recorded on the Fostex is ~1007 Hz (both set at 44100/24). The analog out of the Maudio is what is being recorded by the Fostex. I would think this excessive for two crystal based clocks, I did expect some small difference doing this but not that much.
Silence is so accurate.
Old 12th May 2014, 11:30 PM   #2
This sounds like 48 : 44.1 kHz difference. Any misconfigured settings?
Old 13th May 2014, 05:49 PM   #3
Found the problem, the Maudio Duo is off at only 44100 kHz. It's actually 44400 kHz. !!!??? Or at least effectively that since a bench frequency counter on the analog out gave the same 1006.8kHz that the recorder saw, also checked the recorder against a frequency standard and it was perfect.
Error rates on pcbs. nigelwright7557 Class D 15 2nd January 2012 09:06 PM
U.S. Postal Rates jackinnj The Lounge 8 18th May 2007 06:00 AM
Question about sample rates cuallito Digital Source 2 25th April 2004 02:15 PM
Sample rates Prune Digital Source 9 18th September 2003 07:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
