Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Shigaclone MKII Black - The builders Thread
Old 29th December 2014, 11:55 AM   #911
weskoki is offline weskoki  Europe
weskoki's Avatar
Oh thanks Tibi!
Old 29th December 2014, 10:03 PM   #912
Aleks1 is offline Aleks1  United Kingdom
Aleks1's Avatar
Default Picture of my shigaclone.
Hi Everyone,
thought I'd post a pic of my Shigaclone. I put the the PSU in the bottom box and have upgraded it so that there are four individual regulators that connect via an amphenol 62GB mil spec multipole connector to the main transport. Overkill, but I needed to fill that bottom box up. The box that houses the transport has a 1 inch copper bottom for a bit of ballast.
Just need to polish the front panels and fit an on/off switch.
It sounds wonderful.
Old 30th December 2014, 06:07 AM   #913
tvicol is offline tvicol  Romania
tvicol's Avatar
Shigaclone MKII Black - The builders Thread Shigaclone MKII Black - The builders Thread
It looks solid.
"It sounds wonderful." is all that matter.
Thank you for feedback.
Tibi
Vicol Audio
Old 30th December 2014, 12:07 PM   #914
alfred wan is offline alfred wan  Malaysia
Aleks1. Cool finishing and huge!! Oh Mighty transport.
Old 30th December 2014, 12:10 PM   #915
Hi Tibi,
I checked the ribbon. On the pcb side, I had tried to push in as deep and still can see about 1mm copper trace. Should I go further? it seems quite tight.
Old 30th December 2014, 01:26 PM   #916
tvicol's Avatar
Originally Posted by alfred wan View Post
Hi Tibi,
Push as long connector allow you. Make sure it make perfect contact. Use a contact spray if necessary. Another important thing is do not twist this ribbon cable in any way.
Tibi
Vicol Audio
Old 31st December 2014, 06:26 AM   #917
nbivol is offline nbivol  Turkey
Tibi,
Would original JVC EZ-xx remote control work with MKII?
Old 31st December 2014, 06:30 AM   #918
tvicol's Avatar
Originally Posted by nbivol View Post
Tibi,
Yes.
Tibi
Vicol Audio
Old 31st December 2014, 10:08 AM   #919
Prinz is offline Prinz  Netherlands
Dear Tibi,
Finally a status report from my side. I am using the holiday time to work on the Shiga kit. I am progressing well! Maybe you could help me with a few little issues:
A. I do believe i am missing a few parts, i checked many times, but they are not there.
ADP151
1uF keramic 1206 smd (2 pieces)
IR transmit diode in the remote control
The schematics of the remote control.
I would appreciate if you send these to me.
Thanks all of you for sharing the building info, it helps a lot in getting everything together.
Best regards and i wish all of you a happy 2015,
Paul
Old 31st December 2014, 10:50 AM   #920
tvicol's Avatar
Originally Posted by Prinz View Post
Dear Tibi,
ADP151
Paul
Hi Paul,
ADp151 and 1uF caps are part of optional parts. In fact I do not use this in standard or high-grade.
Double check for IR, must be there.
IR schematic is on my website. vicol audio : Shigaclone mkII CD transport
Tibi
Vicol Audio
Shigaclone MKII Black - The builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F3 Builders Thread Melon Head Pass Labs 622 10th January 2018 06:10 PM
El Cheapo, builders thread tinitus Tubes / Valves 26 16th May 2015 06:10 PM
WTB: Black Gate caps and Citizen crystal for JVC Shigaclone Tape Echo Swap Meet 3 10th August 2013 09:08 AM
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 366 14th March 2013 03:31 PM
